It is currently Mon Aug 03, 2026 1:06 pm
PostPosted: Wed Sep 03, 2008 5:04 pm
Does anyone have a good way to keep their trapeze bungees from cutting into their rail rugs? I am carving out quite the grooves and have snapped a few bungees in the process.
I am thinking about adding a stainless steel bar on the outside of the pylons to run them around. Also I saw some of the newer hobies run the bungee through a grommet on the tramp. Can I add a couple of grommets without compromising the strength of the tramp?
PostPosted: Wed Sep 03, 2008 7:52 pm
This thread has a couple tips.
http://www.hobiecat.com/community/viewtopic.php?t=10454
PostPosted: Thu Sep 04, 2008 6:19 am
I'm thinking about doing this next season. Just make sure you grommet the reinforced edge. Punching a hole will obviously break the seam but if the grommet is tight maybe it won't matter.
PostPosted: Sun Sep 07, 2008 7:03 pm
Thanks for the link. I like the pulley system, but I don't like that it isn't race legal.
I think I am going to try the grommets this winter. I will probably take the tramp off, sew four square pieces of mesh into the tramp and tap the grommets through those as a precaution.
