It is currently Mon Aug 03, 2026 5:10 am
 Post subject: tramp lacing
PostPosted: Tue Mar 10, 2009 5:54 pm
This year i have to re-lace my tramp... it is now laced with shock cord...
any comments on what is best??? and what weight of line and how much stiffer the boat is with line instead of the Shock Cord?????
•Present boat -1998 Hobie 16 Solana Sails furling jib[/size]
PostPosted: Wed Mar 11, 2009 5:49 am
I tried shock cord for a couple seasons but it is expensive and doesn't last very long (frays and chafes). If you have a very old vinyl tramp then shock cord will give (stretch) and help prevent rips and grommet pulls.
PostPosted: Wed Mar 11, 2009 6:02 am
use 1/4" yacht braid, or something low-stretch, and then follow instructions by Matt Miller from an older thread
Better than that...
On a 14 or 16 you can "pre-bend" the sidebars before tensioning the center lace. We do not use double grommets down the center and get tight tramps without a huge effort.
Use the mainsheet system. Lay the blocks and line on the tramp "unsheeted" from side to side bar... in the center. Add a line to the base of the blocks that can reach around the sidebar, under the tramp and meet the top block. Tie off. Pad the side bars with some cardboard where the line goes around the sidebars. Sheet the system to bend the sidebars in by over 1". We sheet till the tramp gets a little pucker shape along the sidebar. Cleat the blocks and tighten the tramp using moderate tension. Using the vise grips, dowell or just holding the line at each grommet as you go. Tension the aft lace last and then release the block set.
We use this system and get over 1-2 inches of prebend in the bars for over 1 inch after releasing.
Worst loads on a grommet are during tensioning each one... this saves effort and grommets.
Sheet In...Max Out
www.fleet297.org
PostPosted: Wed Mar 11, 2009 12:31 pm
Never thought of pre-tensioning side rails. Great idea. I think I'll try it with a ratcheting tie-down strap.
PostPosted: Wed Mar 11, 2009 1:19 pm
Well... you learn when rigging up to 64 boats at one time!
PostPosted: Wed Mar 11, 2009 7:01 pm
Matt sometimes I am jealous you get to sail all day.... but when i look at that picture above.... i dont think i would want your job anymore... that looks like alot of work... unless the Hawian Tropic girls were helping you that day and you just cant see then in the picture
PostPosted: Wed Mar 11, 2009 8:59 pm
thanks for the tips.... i will try the line this time... and see if the boat is tighter ......
PostPosted: Thu Mar 12, 2009 5:41 am
You might want to use a tramp tighter in addition to the blocks, does help to preload the lacing before you release the blocks.
http://www.thebeachcats.com/OnTheWire/h ... /tip21.htm
PostPosted: Thu Mar 12, 2009 9:10 am
Nope... no Hawaiiann Tropic Girls. Actually... little if any sailing for the crew during these Worlds regatta trips. We don't test sail the boats or anything. That shot was from New Caledonia. There was the ocassional topless french woman near by though!
PostPosted: Thu Mar 12, 2009 9:50 am
That was almost 7 years ago Matt and I think you may have forgotten the reality of that sight. It sounds pretty good now but at the time I think we were washing our eyes out with soap. :shock:
Greg Thomas
Hobie Factory Team
PostPosted: Thu Mar 12, 2009 11:12 am
Ok, so they were older french women. I liked my memory better!
PostPosted: Thu Mar 12, 2009 10:26 pm
Remember G, Matt's got a couple of years on us!
J
PostPosted: Thu Mar 12, 2009 11:06 pm
J
Age or poor memory, it doesn't matter; I like Matt's memory, too. Don't burst the fantasy bubble.
PostPosted: Fri Mar 13, 2009 7:27 am
It was a GREAT story :)
till SOMEBODY had to hose it all up with the Details. :cry:
Somebody go slap Greg ! :P
S
PostPosted: Sat Mar 14, 2009 6:30 pm
Speaking of topless which should be legal here, check out the land down under.great sailing, double bonus,later aussie bob.
