It is currently Fri Jun 19, 2026 6:08 pm
 Post subject: mast angle
PostPosted: Wed Jul 01, 2009 8:31 pm
What is the suggested degree angle that the mast should be at for the new model boats? We have had several experienced sailors stop us to stay our mast is leaning too much and should be closer to 85 degrees. On the other hand we have been told the new boats should be closer to 78 degrees.
 Post subject: Re: mast angle
PostPosted: Thu Jul 02, 2009 7:04 am
Nobody measures their mast angle because that's not what's important. Certainly without the jib, the mast will lean back at a crazy angle because of the slack forestay.
With the boat rigged (main and jib) on the beach, sheet in the main. Do the blocks come together easily? (too much rake) Or do you have to really crank the mainsheet that last foot or two to get them to touch? (just about right).
That's what's important - the ability to sheet the main in all the way and still get enough leech tension in the sail.
