It is currently Mon Aug 03, 2026 3:41 pm
 Post subject: shim a hobie 16
PostPosted: Fri May 28, 2010 11:56 am
what is the best method to shim my 16? can i use shim stock like brass or will it react?
 Post subject: Re: shim a hobie 16
PostPosted: Fri May 28, 2010 12:17 pm
i used pennies, quarters, and dimes....i had very little play however, just in the sidebars....they would twist a little bit, about 1-2mm
1981 Hobie 16
1982 Hobie 14 turbo (sold)
1996 SeaDoo GTI
1999 Hunter 340
PostPosted: Sat May 29, 2010 7:20 am
I went to Lowe's and got some aluminum flashing strips (in the roofing supplies section). I tried beer cans but the aluminum was curved, not very stiff and ripped easily.
PostPosted: Sat May 29, 2010 9:22 am
The best way is to shim it with thickened epoxy. Use 404 high density filler, glue it, be done with it. Look up 'gluing your boat' in the forum search.
Hope that helps.
Sail Revolution
Join us on our new FB Page!
