It is currently Sat Jun 20, 2026 7:37 am
 Post subject: Rudders
PostPosted: Tue Aug 03, 2010 7:34 am
On my hobie 16 the rudders will not lock down. I checked the cams and they are not broken but they do not rotate. I'm not sure if the cams are suppose to rotate? Can anyone help?
 Post subject: Re: Rudders
PostPosted: Tue Aug 03, 2010 10:11 am
Yes they should rotate. Yours are likely locked down. Look at the base of the cam in the casting. There is a plunger that is spring loaded. Force the plunger down with a small blade screw driver to release the cam. Lubricate with some heavy grease.
Read up on this FAQ here: http://www.hobiecat.com/community/viewtopic.php?f=18&t=467
