It is currently Sun Jun 21, 2026 1:43 am
PostPosted: Mon Aug 23, 2010 6:57 am
Used acetone to clean 34 years worth of stain off the blades, sanded down with 80,120 and 240 grit, then used rattle can for the coating
Resolution is low on the iphone camera, but all in all not a bad way to spend 3-4 hours (six pack) waiting for the rain/humidity/heat index to subside.
War Damn Eagle
Branson
PostPosted: Mon Aug 23, 2010 9:20 am
Murphy's Law of Work vs. Longevity:
The more work you spend in restoring something, the more likely it's going to break in the short term.
ABS rudders on a Hobie 16 = break off at the rudder casting.
PostPosted: Mon Aug 23, 2010 9:48 am
Old man Murphy can be a jerk. There are some epo blades I have my eyes on just in case. Plus football season is just around the corner and the Hobie needed some collegiate colors.
War Eagle!
Branson
War Damn Eagle
Branson
PostPosted: Mon Aug 23, 2010 6:19 pm
I did the exact same thing to mine except I painted them black. It worked great. One of my rudders has a crack originating from the top hole. I drilled the end of the crack and filled with epoxy. So far so good with 2 sailing seasons. I know one day the rudder will fall off into the lake, but until then, SAIL ON!
BTW, good job!
'88 Nationals Blue
Hobie Alter Signature Model
Sail #11
Hobie Mirage Classic
PostPosted: Fri Aug 27, 2010 9:07 am
yea my rudder broke off at the top at the "pin hole" last nite as I was putting them back on the boat .. better at the house than in the Gulf !
'99 WAVE
Gulf Breeze, FL
