It is currently Sat Jun 20, 2026 11:10 pm
PostPosted: Thu Apr 21, 2011 6:40 pm
Just received a new factory jib for my 16. I noticed a change. It came with a stay shackle at the head of the sail in lieu of the foot as my last one was where attaches to headstay. The H-16 parts IPB also shows it at the bottom. Does it even make a difference? Also noted the stay shackle is riveted instead of removable pin of which is a good move. Another thought, one wouldn't want stay shackle connection at top and bottom would you?
TIA
Gulf waters are warming up!
UK Wildcats have 8 now!
1976 H16 27640
1985 H16 89112
PostPosted: Wed Apr 27, 2011 7:18 am
btt ??? Any help here?
1976 H16 27640
1985 H16 89112
PostPosted: Wed Apr 27, 2011 7:52 am
Hi Tia, My best guess is the sail is now made that way so it is easier to adjust as it is pretty hard to get to when the jib is up. I drilled out the shackle rivet on my jib and replaced it with a shackle at the top putting the adjustment tie on the bottom so it could be adjusted if needed while the jib is up.
07 H16
Sail No. 110387
PostPosted: Wed Apr 27, 2011 8:44 am
Thank you!
1976 H16 27640
1985 H16 89112
