It is currently Sun Aug 02, 2026 6:45 am
PostPosted: Fri May 19, 2006 8:48 am
Hi everyone - last summer my traveler cleart/swivel assembly separated from the rear crossbar on my Hobie 16.
I looked carefully at it and it appears that the swivel attaches to the crossbeam in 3 places. One screw aft of the swivel, and 2 screws under the swivel itself.
All 3 had stripped.
I replaced the aft screw with a rivet which has loosened up.
The 2 screws under the swivel are not biting at all.
Should I tap larger holes for new screws?
Is there a nut inside the rear crossbeam that a bolt would thread into? (that would be ideal)
Or should I put 2 new rivets in place of the 2 screws (under the swivel)?
I've had a difficult time finding rivets long enough to span the swivel plate down into the rear crossbar.
Thanks for your help!
G
PostPosted: Sat May 20, 2006 7:42 am
Authorized Hobie Dealer
I would put a larger diameter sheet metal screw in, no there it no nut inside the cross bar.
Thanks,
Brad Stephens
www.sunjammers.com <---new online store coming!
Hobie Division 15 Chairman
Authorized Hobie/Vanguard/Hunter Dealer
Panama City Beach, FL
PostPosted: Sat May 20, 2006 7:45 am
Actually I ended up tapping new threads and putting a stainless steel machine screw in there. It worked like a charm AND I got some new tools out of the deal! There's absolustley no play in the swivel base now. It's not going anywhere.
Boats are so cool :)
G
PostPosted: Sat May 20, 2006 8:07 am
happy to hear that you were able to fix your problem, yes Boats are cool, especially Hobie Cats!! Let us know if you have any questions!
Thanks,
Brad Stephens
