It is currently Sun Aug 02, 2026 1:50 pm
PostPosted: Sun Jul 02, 2006 5:09 am
Hi everyone, I can't seem to set enough mast rake on my 79. At best I'm able to get into the 4th hole from the top (barely) on the shroud adjusters and we're a fairly light team. 275lbs total weight.
I'm putting the forestay in the top hole if the forestay adjuster. Do I have a short forestay wire??? How long should it be on a 1979 setup??
Am I missing something? How much force is used to pull the side shrouds down into the adjuster?
 Post subject: Forestay
PostPosted: Sun Jul 02, 2006 8:11 pm
Yes, It is quite possible the forestay is short. Add an extra 10 hole adjuster to make the system longer.
