It is currently Sun Aug 02, 2026 1:50 pm
 Post subject: Draining Hulls
PostPosted: Wed Dec 13, 2006 12:31 pm
I was draining the hulls of my '87 16 last weekend, and something peculiar happened:
The one hull that had more water in it than the other-- had small flakes of plastic that built up by the hole where the water was coming out, restricting the flow.... Once i reached in and took the flakes out, then the water drained cleanly (implying that the flakes were floating around in the hull).
It seems like that plastic might be pieces of the inner lining?? Don't know.. I am worried about this.
(the flakes were clear, thin, about 1/2 an inch in diameter..., maybe enough of them that if they were placed end to end would lead to a piece of plastic about 3 inches wide...)
PostPosted: Wed Dec 13, 2006 2:13 pm
There are all kinds of weird little pieces of resin and glass that end up in the hulls. I think most of them come from the manufacturing process - before the decks are glued to the hulls - little bits and pieces of trimmings, etc. fall on the deck or into the hulls.
Fiberglass manufacturing is not exactly the cleanest environment.
I wouldn't worry about it.
 Post subject: Me too
PostPosted: Fri Dec 15, 2006 11:35 pm
I get them some times on my 86 17. Just pull them out and go on. Guess over the years they just flake off?
Doug
