It is currently Fri Jun 12, 2026 11:41 am
PostPosted: Mon Jul 31, 2017 1:47 am
My boat has 2 orginal "butt bucket" style harnesses, blue with big yellow flying H on the backs. Anyhoo, we set the boat up in the back yard yesterday and I was going to show my son how the harness worked. He put it on and it fit him fine but I don't understand how the center "crotch" strap part works. These harnesses have never been used and I kind of wanted to give them a try this week, could someone explain how you wear these things?
Thanks.
Marty
Lake Martin, 'Bama.
PostPosted: Mon Jul 31, 2017 3:37 am
If the hook plate is square with slots for straps, then the crotch strap goes through the bottom slot and then you insert a 3/8" rod through one of the slots in the strap (multiple slots allow for size adjustments). A piece of rudder pin or wooden dowel works fine as the rod. I used to tape the rod in place (duct tape) to keep it from slipping out.
PostPosted: Mon Jul 31, 2017 6:38 pm
Ahhh, okay I see now. The crotch strap on these have multiple adjustment settings. In the tool kit that came with the boat, there are two nylon/plastic short rods. I wondered what they were for. They probably were used with the harnesses. Thanks.
Marty
Lake Martin, 'Bama.
PostPosted: Wed Aug 02, 2017 8:35 am
Yep, that's what the plastic rods are for. I have one of those old diapers and prefer it for casual daysailing when I don't think I'll be on the wire much. It kinda sucks for long periods on the wire though.
