It is currently Sat Aug 01, 2026 10:38 pm
 Post subject: Mast and stepping pin
PostPosted: Tue Apr 03, 2007 5:57 pm
Ok,
I am kinda new to the Hobie 16 deal....Back in the day of my teen years I owned a 14. The 14's mast swiveled in the base. There was no pivot pin to step the mast...you just lifted it up and went to town.. The 16 however, has the pivot with the pin....for steping the mast....once the mast is up, it appears that it should be able to rotate in the base as the 14 did. However, with the pivot still pinned this is impossible. My question is....do you un pin the pivot so that the mast can rotate in the base? or do you leave it pinned? I would assume you would un pin the mast so it was free to turn. Any replies would be great. Looking forward to putting in in a couple weeks.
LAter,
Jim W.
Savannah, GA.
PostPosted: Tue Apr 03, 2007 6:19 pm
yes. definitely remove the pin. i've ruined one of my hinges already by forgetting this step.
PostPosted: Tue Apr 03, 2007 6:30 pm
Very Good....This is what I figured. IF the pin I have is currently bent, does anyone have any good ideas where I can pick up a replacement, or something equal.
Thanks,
PostPosted: Tue Apr 03, 2007 8:54 pm
Any proper size clevis pin will work. I've seen screwdrivers used in a pinch.
 Post subject: Hinge pin
PostPosted: Wed Apr 04, 2007 7:48 am
Murray's Marine has a hinge replacement kit for about 14 dollars that includes the hinge, pin and spring. The stainless in the replacement hinge is much more robust than the Hobie hinge. When I rake my mast all the way back there is interference with the top of the hinge, so I had to file some of the hinge for better clearance so that the mast can rotate unhindered.
PostPosted: Wed Apr 04, 2007 12:46 pm
Unfortunately Mdgann you quoted the price for the hinge only with no pins. The complete kit from M's, is $25. The Hobie part #is 21380001 for $19.95
Wubbena, your closest AUTHORIZED Hobie dealer is:
OCEAN MOTION SURF CO.
1300 OCEAN BLVD.
ST. SIMONS ISLAND, GA 31522
Phone: 1-912-638-5225
or
TIMEOUT SPORT AND SKI
675A JOHNNIE DODDS BLVD.
MOUNT PLEASANT, SC 29464
Phone: 1-843-388-6266
E-mail: [email protected]
Try them. It's good to establish a relationship with your local dealer. They can usually answer all the questions you have about your boat.
Sail Revolution
Join us on our new FB Page!
PostPosted: Wed Apr 04, 2007 5:06 pm
I actually prefer the screwdriver. When it gets dropped in the sand its real easy to spot. I remove my hinge entirely from the boat. As someone said before when the mast is raked back the base can hit it. I've destroyed a couple capsizing as well. Boat goes turtle, hinge swings up (or down in this upside down case), and when the boat comes back up it gets mangled
PostPosted: Wed Apr 04, 2007 8:17 pm
Thanks everyone....this is all great info..I will get in touch with those dealers for other parts that Im going to want as well.
Thanks all!!!
Later,
Jim
PostPosted: Thu Apr 05, 2007 1:31 am
Don't you use the spring which gently holds the hinge down?
PostPosted: Thu Apr 05, 2007 5:38 am
I've never seen the spring. :?: None of my boats have had it.
 Post subject: Spring
PostPosted: Thu Apr 05, 2007 9:35 am
Hobie has not used a spring in the step link kit since the late 80's. I modified the link at that time to make it tougher and not bend as easily. Pretty bullet proof now.
