It is currently Sun Aug 02, 2026 7:53 pm
PostPosted: Thu Feb 27, 2020 10:57 am
Hello All,
I have seen old postings of a bracket that pinned to the dolphin striker that held a battery and a 12 volt fishing motor. Looks so much better the the rear mounted brackets that I see now. The company that made them no longer exist. Does anyone know where one can be acquired? Looks like a simple thing to make, but easier to buy. I'm looking to use boat ramps that are not sail friendly and this center mounted, easily removed rig seems Ideal. Any ideas or suggestions are most welcome!
PostPosted: Mon Mar 02, 2020 6:30 am
Sounds easy enough to make if you have pictures. I haven't seen that one do you have a link?
I was thinking of something like a mirage drive or a pedal powered outboard type drive mounted up front. It would need to pivot and swing out of the way.
84 14T Redline #67 Blue Hawaii faded but still working!
82 Yellow hull16 '81 Boomer nationals 20.9 on GPS
83 White hull 16 No sails "Clean and Purty Now!"
87 White hull no sails no tramp
PostPosted: Tue Mar 03, 2020 11:45 am
I agree, a water proof self powered unit is best! ImageImage I found a PDF on line with lots of good info. I don't think I can post it though
PostPosted: Tue Mar 03, 2020 4:17 pm
A good old fashioned paddle works in most cases. Lol.
Marty
1984 H16 Yellow Nationals Redline, "Yellow Fever"
Lake Martin, 'Bama.
PostPosted: Tue Mar 03, 2020 4:43 pm
I can't argue with you there, especially if ya just run out of wind. I do have a paddle. My problem is my launching sites are ramps with narrow convoluted paths out to open water.
PostPosted: Wed Mar 04, 2020 12:40 pm
That aluminum bracket looks deadly to me after my pitchpole launch at the end of last season. I landed at least 10 feet in front of the boat. I think any thing I add on will have nice rounded corners.. Just me though
PostPosted: Wed Mar 04, 2020 1:11 pm
Also adds a lot of weight forward.
PostPosted: Thu Mar 05, 2020 11:00 am
Weight distribution is certainly a concern. Won't be flying a hull with this system installed. Removable with one pin is certainly a plus. I saw a post where two motorcycle batteries were inside the hulls via access plates, better weight distribution. Anybody got experience with rear mounted motor mount? Better yet, a self powered unit of some kind that is not a paddle?
