It is currently Mon Aug 03, 2026 12:39 am
 Post subject: Connecting downhaul
PostPosted: Sun Jul 29, 2007 3:38 pm
What is everyone using to connect the downhaul to the mast? As you can probably guess I have just purchased a used hobie and am re-outfitting.
Thanks.
PostPosted: Sun Jul 29, 2007 8:07 pm
Item T from Murray's.
 Post subject: re:
PostPosted: Mon Jul 30, 2007 6:12 am
I have the cleats. Where do you connect the block on the downhaul kit? I have seen guys put a ring through the hole where the mast step pin goes. I might be missing the point here. A pic would probably help some.
PostPosted: Mon Jul 30, 2007 7:13 am
I ordered and plan to use the "eye strap for boom vang" with fasteners, p/n 2072. It is $2.70 and can be found pp 27 of the current Hobie parts catalogue. It mounts to the sail track with screws- the nuts slide in the track. I'm not sure it will stand proud of the mast enough so the block won't rubit but, I doubt anything but a decent sized tang will do that. I'm going to use it with Harken 2655 and 2658 40mm Carbo fiddles.
PostPosted: Tue Jul 31, 2007 7:55 pm
I have also been trying to figure out to purchase the "class approved attachment for base of mast" which is part of the 6:1 downhaul kit from hobie. On page 27 of the catalog the part is visible in the picture. Perhaps Matt Miller knows the answer? I have found that the shackle through the mast step pin works but wouldn't mind having the "correct" attachment.
 Post subject: Class approved
PostPosted: Wed Aug 01, 2007 9:31 am
The "Class Approved" fitting is the Deck Plate from a traveler car. #11870000. This is installed with screws and square nuts.
PostPosted: Thu Aug 02, 2007 6:21 pm
Thanks for the part number
