It is currently Wed Aug 12, 2026 12:17 pm
 Post subject: Livewell pump question
PostPosted: Sat Mar 27, 2010 3:20 am
Hey guys a have a livewell pump question. I don't own one yet and my dealer doesn't have one in stock. I have watched the video but I can't see clearly. The video says that the livewell uses a Tsunami 500 pump.
My question is.... is this a normal bilge pump or has it been modified? Does it have the base removed from it? Or does the whole pump fit into a pocket inside the livewell? Can the replacement Tsunami cartridge be installed if the pump dies?
Thank you,
Chris
PostPosted: Mon Mar 29, 2010 11:35 am
try this and have a look. the whole thing can be removed easily. I'm sure a substitute pump could be fit with a lil work and some of the originals mounting parts. i have the HOBIE Live well and i have no problems with it. Also a trick you might want to try is to put a ballon cut on the end over the pump outlet/fill pipe to allow shutting the pump of without letting the water run out like a big drain. the balloon will collapse and clog the pipe preventing the water from running directly out. Takes a few trys to get the balloon hole the right size but it works ok for the most part.
viewtopic.php?f=26&t=9383&p=48395&hilit=hobie+livewell+pump#p48395
http://www.jaxkayakfishing.com/phpBB/topic16212.html
http://s909.photobucket.com/albums/ac294/gsammy925/
PostPosted: Mon Mar 29, 2010 2:26 pm
Thank you for the close up of the pump. It is threaded on the bottom... sweet!
