It is currently Wed Aug 12, 2026 1:16 pm
PostPosted: Fri Feb 19, 2016 10:30 am
Hello I am brand new to the forums as I have just purchased and received a 2016 outback.
Several quick questions as I am receiving different answers from different people....
1. on photo 1. is this how the bottom of your yak where they drilled the scupper holes supposed to look??
2. on photo 2 and 3, are the flanges from the kayak cart that support the weight supposed to actually somewhat insert into the bottom of the scupper hole or is the keel just supposed to rest on top of the flanges .. because these flanges don't insert at all into the scupper holes....
3. does it matter which way north/south and west/east the flange rest on the keel since the flanges have a specific shape to them?
Lastly, they installed my anchor trolley about 2.5 feet from the end of the boat.. my other kayaks had the end pulley about 1 foot from the end.. I am concerned that this new distance is going to not have me perpendicular to the waves, hence I will be getting more of a "wave crash" effect when fishing.. the dealer has agreed to move it but I wanted to get a feel from the forum first before I drive the 50 miles again... They also put the "Cleat" on top of the rails instead of on the side of the kayak so now when I have my kayak upside down in the truck, the kayak doesn't sit flat, it sort of rocks on the cleat.. I told them I want that moved as well to the side....
Thanks to anyone who can help!
PostPosted: Sat Feb 20, 2016 7:32 pm
Nobody on the forum here has ever used the official hobie kayak cart to move around their hobie? I am brand new to the forums, can somebody here at least advise me if these forums are not a good source of info for questions so I can search elsewhere.
Thanks!
PostPosted: Sat Feb 20, 2016 10:07 pm
My kayak cart flange does not insert into the scupper holes. They are big enough to stop to cart from going to far in. You should be able to adjust their height so the crossbar of the cart does not touch the bottom of your yak. It should sit just above the crossbar but be far enough in to insert the pin to keep it from falling out. My PA is so heavy that these flanges slide to the bottom no matter how tight I make them. If this happens, you can cut a small piece of PVC pipe to raise them up a bit. The alignment should coincide with the scupper hole area. So it sit snug and does not cause pressure points.
Also, the scupper holes on the bottom of the boat are rough like yours. They just aren't sanded like the top ones. Image
______________________
The Mama Cocha
Hobie PA 14 / Illinois USA
Sent from my iPhone
The Mama Cocha
Hobie PA 14 / Illinois, USA
PostPosted: Sat Feb 20, 2016 10:59 pm
The Outback on Hobies home page shows the trolley only going part of the way down the side. I guess it's personal preference ok how long you want your line to go. Image
The Mama Cocha
Sent from my iPhone
The Mama Cocha
