It is currently Wed Aug 05, 2026 7:30 pm
PostPosted: Fri Feb 06, 2015 2:52 pm
Matt, could you post the mounting hole spacing dimensions for the TI cradles?
Thanks, John
John Robb
2015 TI Azul
Sarnia ON. CAN.
PostPosted: Sun Feb 08, 2015 10:51 am
John, I just happen to have one lying around. From the center hole mine measures 19 13/16 to the left and 19 15/16 to the right hole. That is with it sitting flat on a table. The holes are 3/8". I wouldn't pre drill anything to these dimensions, there may be some variation as you can see from the difference on my cradle. I thought 3/8" was a bit large for the mounting bolts and put a plastic tubing bushing in the holes to reduce to 1/4" for my TI cart and also used fender washers to spread the load on the plastic.
- Chris
PostPosted: Mon Feb 09, 2015 3:50 pm
Only spec I have is spacing between cradles. 67"
PostPosted: Mon Feb 09, 2015 5:02 pm
Thanks for the info Chris. I've purchased a 2015 Tandem Island and want to outfit a trailer prior to delivery.
John
John Robb
2015 TI Azul
Sarnia ON. CAN.
PostPosted: Wed Feb 11, 2015 10:38 pm
Mike, was that 67" from back edge of forward cradle to front edge of rear cradle, or center line to center line?
Sent from my iPad using Tapatalk
PostPosted: Thu Feb 12, 2015 8:53 am
On center.
