It is currently Wed Aug 12, 2026 2:02 am
 Post subject: Mounting a Helix & 360
PostPosted: Wed Mar 22, 2017 5:20 pm
What are you folks using to mount your bigger screens? I just ordered a Helix 9 and need some ideas.
Also got the HB 360 transducer (trolling motor) and I need to figure out a way to mount it off the h-rail so it can stow parallel to the h-rail and obviously deploy straight down off the side.
Appreciate suggestions
PostPosted: Fri Mar 24, 2017 6:39 am
I'm at work, but as soon as I get home, I'll post a picture of my rig. I bought two Ram mounts so I could have options. I have the Helix 10, so I bought the large Ram components (D-size).
Option 1: I drilled into the plastic mounting plate on the front starboard side. Then I mounted this...
http://www.rammount.com/part/RAM-D-202-25-C-202U
However, I found I like the head unit closer to my face, so I bought a D-size ball-clamp component and tightened it around my h-bar close to the seat. I LOVE this setup because it brought the screen closer to my face. I used some bicycle tube from walmart to protect that area of the h-bar from the ram clamp. The rubber on the tube also provides friction and prevents ANY sliding on the h-rail.
http://www.rammount.com/part/RAM-D-271U-12
PostPosted: Mon Mar 27, 2017 11:23 am
For mounting your head unit, a 1.5" H-Rail Ram ball will do the job. If you're only interested in the 2.25" RAM ball, then I'd mount to one of the mounting boards on your PA.
Howie Strech
PostPosted: Thu Mar 30, 2017 4:35 am
Thanks I went with the 2.25, looks sturdy
