It is currently Tue Aug 11, 2026 5:39 pm
 Post subject: 2013 v 2014 PA
PostPosted: Wed Oct 16, 2019 3:56 pm
I am looking at buying a second hand PA 12 and was wondering what the differences between the 2013 and 2014 models are? I believe there is the upgraded rudder and BOA on the 2014 model but could be wrong?
Are they effectively the same boat or should I preference a 2014 model?
Thanks guys
 Post subject: Re: 2013 v 2014 PA
PostPosted: Thu Oct 17, 2019 11:44 am
The only difference I know in the PA14 between the 2013 and 2014 models was the BOA rudder tension mechanism was added to the 2014 model. Pretty sure the PA12 followed the same upgrade schedule. :wink:
Steve Stubbs
USAF (retired)
SeaDek Fishing Team
Unfair Lures Pro Staff
Ziptailz Ambassador
2015 Pro Angler 14 - Papaya
2018 Compass - Sea Grass
PostPosted: Fri Oct 18, 2019 6:26 am
You can also upgrade the 2013 PA by buying a BOA kit and installing it yourself......I made this upgrade on my 2013 PA-14.
Its well worth adding the BOA that takes the "slop or tightness" out of the rudder lines as the hull changes slightly (expands or contracts) as the ambient temperature changes.
Dr.SteelheadCatcher
Warrenton, OR
PostPosted: Fri Oct 25, 2019 10:34 pm
My friend and I just purchased PA12s this year. Mine is a 2013, his is a 2014. The only differences that I have noted is the BOA tension adjustment and the rudder mount/steering drum was upgraded.
