It is currently Sat Aug 01, 2026 11:18 am
Post new topic Reply to topic  [ 16 posts ]  Go to page Previous  1, 2
PostPosted: Sun Aug 21, 2016 8:38 pm
I can replace these one by one. How do I tell if the holes are wallowed out? I can see the surface of the Al casting, but that is about it.
I just took apart a frame that was sloppy. The holes in the extruded aluminum were egged out bad. Larger rivets wouldn't help at all, as the holes were about 3/8" wide. You may want to take off the corner castings to see what you have and add epoxy to the joint. You may want to add some fresh holes for rivets, so you're in a fresh area of the extruded portion. The cast portion holds up a lot better than the extruded part, so you can't tell how bad the holes are without removing the castings.
JKK
83 yellow/ white decks Hobie 14 Corando turbo
82 yellow hulls Hobie 16 Cat Fever
84 yellow hulls hobie 16 Yellow Nationals
plus a few extras that I'm restoring
