It is currently Sat Aug 01, 2026 10:20 pm
 Post subject: beach storage
PostPosted: Fri May 02, 2008 2:28 pm
Hello all, I plan on keeping my H16 on the beach this year. Just looking for any info on how to secure it to the beach along with the beach wheels so they don't get blown over or stolen. Thanks for any help.
Brian
1980 H16
PostPosted: Fri May 02, 2008 4:41 pm
I recall this basic suggestion read on this forum. I will kind of expand upon it:
Take two 5 gal pails, drill a good size holes near the top of each one, but no closer than say 2" from top. Don't be tempted to use those handles instead. Run a length of cable or chain thru to make a loop, and splice together.
Place one bucket aft and one fwd near pylons, opposite corners, idealy closest to and in line with prevailing wind direction. Start digging! Make sure holes are deep enoungh to place bucket well below grade, so that once burried only small loop of chain/cable is exposed, (be sure splice is burried too). If it is really stormy/windy where you are, use four!
Once you have your beach anchors in place, simply attach tie downs to the chains, and maybe use some sort of locking cable around a pylon to one of the chains.
Not so sure about the beach wheels. Do they slide under the tramp? If so, tie off to pylons, and drill a hole (on beach wheel shaft or somewhere) to run a bicycle locking cable to one of the pylons.
Won't be theft proof, but will slow them down.
Jim
2007 Hobie Wave
PostPosted: Sat May 03, 2008 9:26 am
For the beach wheels I do something similar to what was described in the last post. I was lucky enough to find a bike cable that has a loop at each end. I wrap it around the axel and pass one loop through the other. Then take the free end and lock it to the dolphin striker.
If you are just trying to keep joyriders from fooling with your boat, that is probably enough; they can't use the wheels to move the boat, and can't drag the boat because of the wheels.
PostPosted: Sat May 03, 2008 6:52 pm
Buy 2 earth anchors and turn them into the ground front & back. Tie a line from the front and rear crossbar to each anchor, keep the line tight. Get two bike cables and locks, wrap around the two crossbars and lock to the earth anchors to keep people from moving it.
This worked well on my H-18 last summer. :D
1989 Hobie 18 Worlds Boat, Magnum Wings & Spinnaker
1987 Hobie Holder 20 #273
dale.vanlopik"at"att"dot"net
PostPosted: Sun May 04, 2008 4:28 am
Thanks for all of the replies. Sounds pretty simple. I'll let you know how it goes. Thanks again, Brian.
1980 H16
PostPosted: Sun May 04, 2008 9:46 am
Is this the same JoseyWhales that leaves dead men wherever he goes ??? :lol: :lol: :lol: :lol:
Happy Sailing,
David
 Post subject: Sand Anchors
PostPosted: Sun May 04, 2008 10:00 pm
Go to your nearest "Arborist/Tree Surgeon/Climber Supplier they have "Ground Anchors" that are used when planting trees. You can get them in lengths from 1' w/ 2" disk to 3' w/ 4" disk ... the softer the soil the bigger the disk and longer shaft required.
Install one under the front crossbar ... one under the rear crossbar ... I've seen boats walk/rotate on a single ground anchor ... I was amazed!!!
To install use a 36" long "breaker bar and a section of pipe to increase the leverage ... I "pre-dig a one foot hole w/ a posthole digger then put the ground anchor into the hole put the dirt back in to help the anchor to "bit" ... then put the breaker bar through the "eye" on the shank and start walking in circles ... you will get DIZZY ...
At my local arborist supply they start a $4 ea and go to approx $12 for the 36" w/ 4" dick I think
At my Yacht club my boat is stored on a "grass lawn" so I make sure to drive my anckors below grade so they can cut the lawn when my boat is "on the road" at a regetta. They get real angry when they hit them w/ the mowers. I've found some Crab Trap/Lobster Trap floats that I tie to the anchors to mark them ... I also have my boat up carpeted blocks so I do not get "gelcoat blisters" and you can use a weed wacker to cut the grass around the boat to keep the YC looking nice.
Screw in "dog anchors" are not long enough to hold a boat down in a good storm ... they pull out especially if the ground is wet from rain
These anchors are also good for hold down your "pop-up" awnings on the beach also .... you know the kind 10'X10' or 12'X12' ...
"You say those horses belong to these here pilgrims...?"
"I've come here to give you life ... or give you death". "Dieing is not so hard for men like us when everyone we have known and loved has been butchered or killed". "The sign of the Commanche will be on our lodges" ... "When the Commanche come north in the spring they can stop here and butcher some of our beef ..." "That is my word of life" ... Therefore you know my word of death is also true".... (reply) "You are the grey rider who will not make peace with the Bluecoats" --- Dialog from "The Outlaw Josey Wales: 1st- scene at the Settlers store ... 2nd- scene w/ Ten Bears ...
Also with the name of Harry everyone liked to call me "Dirty Harry" ---
" was it five or was it six??? Being that this is a 44magnum, the most powerful handgun known to man ... and will blow your head clean off ... and in all this excitment I've lost count ... you have to ask yourself one question ... do you feel luck today .... punk .... well do ya?"
Harry
Ya I'm a "Clint" fan
HarryMurphey
H-18 mag/ #9458
Fleet 54 Div 11
PostPosted: Mon May 05, 2008 5:36 am
I'm not a huge Eastwood fan, but Unforgiven was one badass movie.
PostPosted: Mon May 12, 2008 3:47 am
Thanks for all the advice and information about putting my 16 on the beach. I'm getting back to Jersey on Wednesday and it's going on the beach then. I think i'm going to try the one strap in the front left pylon and another on the rear right. I have access to cinder blocks, so i'm going to use those as anchors. thanks again for all the replies and information.
"Don't piss down my back and tell me it's raining"
1980 H16
PostPosted: Sun Jun 01, 2008 5:01 am
I have had 2 bent masts in the last 2 years... definately tie it down. however I have 3 hobie buddies on the same lake (lake Huron) who have never had a problem. A used H16 mast is running $500. I wish I had asked your question 2 years ago. And I wish i was luckier
