It is currently Sat Aug 08, 2026 10:06 pm
PostPosted: Sat Apr 03, 2010 4:26 pm
I after much thought and consideration have bought a Bravo, It will be Shipped to my Home but in the mean time I am in the process of modifying a trailer to fit. Can somebody measure the inside distance between the hulls, and the distance on centerline of the keel between the hulls.
I thank you greatly,
I will be glad to report my first impressions of my maiden sail.
Mar
PostPosted: Mon Apr 05, 2010 7:16 pm
Just measured mine, 44.5 inches between the center line of the keels and 27.7 inches between the inside of the hulls at the narrowest point.
Charlie
PostPosted: Tue Apr 06, 2010 7:01 am
Thanks Charlie,
I want to have a bunk where the keel is and a vertical one that will keep the boat centered on the trailer against the inside of the hulls, of course I will have to make all final adjustments with the boat on the trailer.
Thanks for your reply
Marlen
PostPosted: Mon Jun 28, 2010 1:45 pm
Thanks for these measurements! The new Bravo I'm picking up tomorrow morning will be living on a boat lift, and I needed to adjust the bunks to fit it; can do that tonight :-) This should be the ultimate in laziness - lower the boat lift, pull out the sail and go sailing!!
I think I will be able to sail more often (stolen bits of time) when I don't have to mess with rigging a sailboat every time I get a free hour or so...
Deb
PostPosted: Tue Jun 29, 2010 11:45 am
And just like that! I paddled the Bravo home from the boat ramp (yes - I know they're supposed to sail.... but I was short on set-up time) and it settled in sweetly on the boat lift I rearranged last night! :D
Actually - it paddled quite nicely!! Not as much of a barge as I had anticipated - I can see how it's going to sail easily in a light breeze. Tonight (hopefully) I'll have time to set up the mast/sail and get them placed on the boat.
Thanks again for those measurements!!
