It is currently Mon Aug 03, 2026 6:06 pm
 Post subject: Where to find this part
PostPosted: Wed Mar 31, 2010 6:47 pm
Rudder cam screw and sleeve? Pictured here
I'm rebuilding the hobie and both screws are missing along with the sleeves. Not sure where to get this locally so figured I'd check online.
PostPosted: Thu Apr 01, 2010 3:29 pm
Here is one place to look. http://www.mariner-sails.com/assembly.asp?id=23179 Clicking on "Pin-rudder castings" will give you more options and a link for the sister screws.
'88 Nationals Blue
Hobie Alter Signature Model
Sail #11
Hobie Mirage Classic
PostPosted: Thu Apr 01, 2010 5:34 pm
Let us know where you are and we can get you connected with your nearest Hobie Dealer.
Sail Revolution
Join us on our new FB Page!
PostPosted: Sat Apr 03, 2010 6:36 am
Corpus Chrisiti, Texas
PostPosted: Sat Apr 03, 2010 6:41 am
WOW $17 for two screws....that's ridiculous!
PostPosted: Mon Apr 05, 2010 9:00 am
You can also use the original cam pin 10470000 PIN RUDDER CASTING $6.50 Each
PostPosted: Mon Apr 05, 2010 10:57 am
Go to a machinist and see how much they charge to make a set. I'll bet it's a lot more than $17.
It's not just two screws.
Take a closer look at them (these are the ones for the 17/18, the 16/14 are similar)
PostPosted: Tue Apr 06, 2010 10:36 am
I could ask him to hand build me a KIA as well...doesn't mean the $100,000 KIA he turns out would be worth it either. Besides I REALLY doubt a machinist is turning each one of these. More likely they have a computer controlled machine to do it. Probably in China. I expected to pay $8 because it's a "boat part" but $17 is high! It's a screw and an threaded tube. I'll have to see what I can come up with for an alternative.
PostPosted: Tue Apr 06, 2010 12:33 pm
Please post pics when you do.
Sail Revolution
PostPosted: Tue Apr 06, 2010 1:05 pm
Like I said...
They work better than the screw-in type. If you keep your cams lubricated, you don't need to touch them for many, many years... if ever.
PostPosted: Wed Apr 07, 2010 7:25 am
Here are the 14/16 pins I did find them for $15. Does anyone have a picture of the original pins?
The original pins were hollow which leads me to believe there isn't a tremendous amount of stress put on them. I wish I had an original so I could see the wall thickness. My first thought was to flare some Stainless steel brake line in there it's cheap and readily available. Another thought would be rather then special make a flared end sister screw, just tap a piece of SS rod and put two screws into it. I have some buddies in the bolt business up in Houston I'll have to give them a shout so I can browse through some inventory.
PostPosted: Wed Apr 07, 2010 8:46 am
Just think of tapping something like this.
and putting two $.50 SS screws into it.
PostPosted: Wed Apr 21, 2010 4:35 pm
Go for it,
A lot of people build their own boat from scratch, I'm sure thats a royal pain but inventing a few new parts your self,I think its cool.
I saw some where that the clew plate for a jib is about 15 bucks!!!! So I cut up a chopping board from the kitchen for free, if it doesn't work well I'll try something else.
It's not just a hobie thing, laser also charge what seems to me to be ridiculous prices for parts, I for one will be making everything I can.
good luck
PostPosted: Sun Apr 25, 2010 7:44 pm
I have just run into the same issue. I don't see that there is a massive amount of load. I'm thinking some 1/4 od pipe and flare the ends. If it doesn't seem stiff enough I will find a rod to fit in the tube and epoxy it in.
What could possibly go wrong ???
PostPosted: Sun Apr 25, 2010 8:13 pm
Your boat could blow up
1981 Hobie 16
1982 Hobie 14 turbo (sold)
1996 SeaDoo GTI
1999 Hunter 340
