It is currently Sat Jun 20, 2026 2:31 am
 Post subject: comptip problems.
PostPosted: Tue Apr 06, 2010 5:36 pm
Ok,had my getaway since 2003,i have noticed my comptip seems to be pulling further into the aluminium section,yes,it is glued but moving dramatically causing the rig to be a little looser the usual when it is in it's usual position.I can't really tension it much more,so will a new comptip eventually be required? :?: The comptip has lost some of the black coating near the join due to wear and tear.
Tasmania's only getaway sailor.
 Post subject: Re: comptip problems.
PostPosted: Wed Apr 07, 2010 10:05 am
The glue isn't holding. Re-seat with new epoxy and add a few (4 or more) rivets. That should lock it in place better.
PostPosted: Thu Apr 08, 2010 12:53 pm
I have a friend who is having the same problem.
Where should I put the rivets? I was thinking about an inch below the joint and evenly distributed in the perimeter of the mast.... Does that seem ok?
thanks,
Guillermo
PostPosted: Thu Apr 08, 2010 1:48 pm
Makes sense to me.
PostPosted: Sat Apr 10, 2010 3:38 pm
So it can be drilled,phew!Now I just have to get the sections apart!!
