It is currently Fri Jun 19, 2026 11:40 pm
PostPosted: Wed Apr 14, 2010 10:05 am
I bought a third hand from Hobie (part no 204). It did not come with any instruction and I want to get the forums opinion before I try and go about installing this thing. It took a while but I think I understand how it is all assembled. The supplied carriage bolt with the cut off edges goes into the traveler track, on go the washers and nut, then the plate and then the top lock nut. The bolt for the clip that holds the tiller goes through the clip,through the plate, and attaches with the lock nut and the remaining exposed threads set down into the traveler track. So Far so good I think....
Question is - How the heck do I get the bolt with the cut off edges into the dang track. Do I have to take off the track or the corner casting off the tramp and then have to re-rivet them back on or can I force the bolt into the track and turn it somehow without damaging the threads?? Any Help out there???
Ed
PostPosted: Wed Apr 14, 2010 10:20 am
Drill out the last two or three rivets on the track, and CAREFULLY pry the track up and slide the bolt it...
order some new counter-sunk SS rivets from
www.surfcitycatamarans.com
8)
1981 Hobie 16
1982 Hobie 14 turbo (sold)
1996 SeaDoo GTI
1999 Hunter 340
PostPosted: Wed Apr 14, 2010 10:24 am
Should insert into the track and rotate easily.
Here are the instructions that should have been with the kit: http://static.hobiecat.com/linked_images/204.pdf
PostPosted: Wed Apr 14, 2010 10:38 am
Thanks for the quick reply - When I was at the boat last weekend I tried to just insert the bolt and turn but there is not way its going to go in easy. Am I missing something. Maybe I need to get some wrenches on this thing. I just did not want to force it until I researched it a little. Thank you for the instructions.
Ed
PostPosted: Wed Apr 14, 2010 10:41 am
ohh i just re-read your post and saw it was the t-bolt....
should go in without a problem...it shouldnt be hard.....
maybe a few of your rivets are poping up a little bit and you are trying to install it over one of them?
1981 Hobie 16
1996 SeaDoo GTI
1999 Hunter 340
