It is currently Fri Jul 03, 2026 9:44 am
 Post subject: carrying water
PostPosted: Thu Apr 15, 2010 9:30 pm
hi there - been some time since I posted here but was wondering about how some of our expedition style folks carry water on board the AI aside from throwing a bunch of water bottles down below. Here in Florida, water porting is a big deal if you don't have access to potable water in between stops...
 Post subject: Re: carrying water
PostPosted: Thu Apr 15, 2010 11:14 pm
2x 6l MSR Drom bags inside the hull (rear), and 6x 2l coke bottles left and right of the cockpit ( 3 each side inside the hull). They fit perfectly if you push them in through the front hatch. A string around the bottle neck makes retrieving easier.
PostPosted: Thu Apr 15, 2010 11:20 pm
For day trips here in Maui, I use a Camelback (3/4 gal) clipped to the bungees right behind the seat under the rear aka support. Not the same, but takes up little space in a underused area.
PostPosted: Fri Apr 16, 2010 5:52 am
I use those soft collapsible plastic containers, roughly cube shaped, robust, Spigot and handle on top.
Holds 20 litres, (42 US Pints ), and conforms to Hull shape wherever it is stowed occupying minimal space.
Fair Skies, Max.
PostPosted: Fri Apr 16, 2010 6:23 am
Me too. They're easy to get through the rear 8" hatch if you don't fill them right up.
PostPosted: Fri Apr 16, 2010 11:21 am
Thanks everyone - will be considering these suggestions!
PostPosted: Fri Apr 16, 2010 9:31 pm
i also carry a few MSR 6 liter dorm lite bags inside the hull just in front of the seat inside the hull. i also carry 2 3 liter camelbacks and a few nalgine 1 liter bottles along the sides of the hull.
Sterling
2008 Papaya Adventure Island with Roller Furler Jib
Post about my jib
viewtopic.php?f=69&t=20991
PostPosted: Sun Apr 18, 2010 6:42 am
Real camelbaks are pricey. Costco currently has High Sierra brand 2 liter camelbaks for $20!! Mine has been out twice. Water is shed by the fabric and water stays cold. lots of storage pockets for everything.
2010 Hibiscus Adventure Island
PostPosted: Sun Apr 18, 2010 10:07 am
In mine, the water gets lukewarm after 2-3 hours so I fill it up with ice first, and then add water. Helps it stay cooler for longer.
PostPosted: Sun Apr 18, 2010 2:40 pm
I use the Chekika 32 QT cooler to carry most my water which is pre frozen in 1.5 or 3 liter bottles. the rest goes in the hull.
PostPosted: Mon Apr 19, 2010 10:01 am
Polecat, like Quirkster, carries a lot of frozen water in his oversized cooler. I carry some beer in my cooler and a couple of small gatorade bottles, but that is about it. I carry my water in 10 L Dromedary bags. These bags are indestructible, last forever. I also put bottles of Gatorade in the bottom the hull. They can get "lost" so you need something to poke them back into the daylight.
PostPosted: Tue Apr 20, 2010 2:17 pm
Ditto on the 10L MSR Dromedary water bladders! Just got another w/my REI 20% off coupon. 8)
Regards,
SedonaAI
'08 Revolution (SOLD!)
'07 Adventure Island
Psalm 107:23, 24 (KJV)
They that go down to the sea in ships, that do business in great waters;
These see the works of the LORD, and his wonders in the deep.
