It is currently Fri Jun 19, 2026 1:33 am
 Post subject: Black deck gel coat?
PostPosted: Mon May 03, 2010 6:21 pm
I've gotten down through a layer of white paint and two layers of blue paint and and have hit what appears to be black gel coat on the decks of my H14. The original hull gel coat appears to have been yellow.
No trace of etched numbers on the hulls after removing some pretty serious paint build-up, so probably no hope of knowing what year the boat is.
Were there ever black decks? I can't see any deck colors in the pdf of sail history.
Thanks for any thoughts.
Bruce
 Post subject: Re: Black deck gel coat?
PostPosted: Tue May 04, 2010 4:46 am
No black decks originally. I think you're into the resin. It looks black because it's semi-transparent and you're looking into the dark interior of the boat.
Look on your front pylons for a 3 or 4 digit stamped number in the aluminum. That's where the pre-1973 serial numbers are.
PostPosted: Tue May 04, 2010 8:44 am
I used Interlux 299E stripper to get down to a very smooth, shiny black surface in several spots - pretty sure it's pigmented, but I'll look carefully again - could have been a re-coat at some point before someone ran amuck with a paint brush. Only paint would bubble up with a stripper designed as more safe for fiberglass gel-coat, right?
No markings on the pylons either. I can see sanding marks under the paint I've removed on the transoms. Guessing the HID is gone.
Anyway, I'm havin' a ball, learning a ton, and planning to buy a new Hobie early on in my next life! As others have said, the forum is an invaluable resource, especially for newbies.
Bruce
PostPosted: Tue May 04, 2010 10:40 am
Pics?
Sail Revolution
Join us on our new FB Page!
PostPosted: Tue May 04, 2010 7:49 pm
Can't see much of the gloss in the pics, but now I'm seeing blue under the black, and two layers of blue over it and white to top it off. Top photo before stripping and coarse sanding, bottom one after. Can I use Marine Tex or Bondo on the deck edge damage?
Bruce
PostPosted: Wed May 05, 2010 10:29 am
Bruce,
I don't really know how to help that situation, hard to tell from pics. It looks like someone painted it with bottom paint, see how it's kind of rusty looking? What happens when you go below the black?
Sail Revolution
PostPosted: Wed May 05, 2010 2:19 pm
I think the reddish hue is due to the lighting.
Beneath the black is another layer of blue - you can see it on the deck edge in the bottom picture. There's light blue and dark blue paint on top of that.
Don't think I have the stamina to take it all the way down to gel-coat so will probably fill all the dings, prime and paint it.
Can I go wrong using either marine tex or bondo to fill small chips and the damage around the edge of the decks?
Thanks.
Bruce
PostPosted: Tue May 11, 2010 7:15 pm
wow! so many layers of paint! thats insane!
1985 Hobie 16 86068
