It is currently Tue Aug 04, 2026 12:56 am
 Post subject: Rudders
PostPosted: Thu May 13, 2010 12:40 pm
Can someone refresh my memory on how the rudders stay locked down. I have this problem when going along and when I sometimes hit an obstacle under water. They will not stay all the way down which really affects how the boat performs. Any parts worn out?
 Post subject: Re: Rudders
PostPosted: Thu May 13, 2010 1:00 pm
The "Cam" rotates and locks over a pin or plate in the upper casting when the rudder is down. Likely this cam is just stuck in the down position.
PostPosted: Thu May 13, 2010 1:06 pm
Rudders and Cam FAQ: http://www.hobiecat.com/community/viewtopic.php?f=18&t=467
If the cam sticks in the down position there are several methods to get it to rotate release. From above and forward of the assembly, lift the upper arm and rotate it aft and out of the way. Loop a line around the cam yank the line to pop the cam open. You can also use the tiller arm to assist this technique by wrapping the line around the cam, then lowering the tiller arm and wrapping the line a few times around the tiller arm. Pull up on the tiller arm which (through the line) levers the cam open. There are several tools that can also be used. I use a large blade screwdriver that can be inserted into the side of the cam to leverage it open. There is also a tool (Hobie Part # 83103 / 2003 Catalog page forty eight) that has a small hook that can be used (by drilling a small hole in the cam to allow it to be inserted) for leverage. You can also use a small flat blade screw driver to work between the cam and plunger... force the plunger down to unlock the cam. I find that this works very well even if the cams are dry and un-lubricated.
PostPosted: Fri May 14, 2010 4:27 am
surfrider wrote:
I have this problem when going along and when I sometimes hit an obstacle under water...
Sounds to me like they are working exactly as they should. If your rudders don't kick up after hitting an obstacle underwater something else is going to break.
PostPosted: Fri May 14, 2010 5:53 am
Understood, but, this happens without hitting anything. I was wondering if the srings were weak and in need of replacement.
PostPosted: Fri May 14, 2010 6:25 am
In my experience, the springs don't tend to "wear out". But, depending on the age of your boat, the whole system may need an adjustment and/or overhaul. This would include properly setting the rudder rake adjustment plates in the top casting (if your boat is so equipped), replacing worn out cams, properly setting the plunger spring tension, and lubricating the system.
The first question would be are your cams rotating propery?
If the answer is yes, then likely all you need to do is tighten the big plastic screw on the underside of the lower casting. The tension on this screw is what controls the spring pressure on the cam.
If the answer is no, then you may need to re-set the position of the rake adjustment plate on the upper rudder casting. You may also need to replace the cams. At the very least, you will want to ensure that the cam/plunger interface surfaces are well lubricated with a thin coating of grease.
I recommend putting your boat on the trailer and locking the rudders down several times to make sure the system is functioning correctly before you leave the beach. It's much easier to get these issues sorted out on land than on the water.
PostPosted: Fri May 14, 2010 9:43 am
Thanks everyone, now I remember someone teeling me about the adjustment screw. :)
PostPosted: Fri May 14, 2010 12:32 pm
Jeremy at Surf City Catamarans made an excellent video (as well as a few others) about how to fix your rudder castings/cams so they are working like new. I actually just went through this process and mine work better than they ever have. I'm at work so I can't site the youtube link, but a quick search should pull it up.
James
86' Redline Hobie 16
Sail # 76909
PostPosted: Fri May 14, 2010 2:29 pm
Yeah... you didn't mention the obstacle was water :lol: If your boat is more than a few years old the adjustment screw is likely frozen solid. If so, a quick and dirty fix to give your cams more tension is to put some shims (nylon washers) under the springs if you are going to replace (or have already replaced) the cams. A spring kit includes a new plunger but I have also inserted the old plunger under the spring to add tension.
PostPosted: Fri May 14, 2010 2:43 pm
How's this?
[youtube]http://www.youtube.com/watch?v=zUUA7l6fzIk[/youtube]
Sail Revolution
Join us on our new FB Page!
PostPosted: Fri May 14, 2010 11:44 pm
Thanks Jeremy, that helps alot.
Eric
PostPosted: Sat May 15, 2010 8:11 pm
this might help...if you dont have the tools Jeremy has, you can burn them out....check out my thread
1981 Hobie 16
1982 Hobie 14 turbo (sold)
1996 SeaDoo GTI
1999 Hunter 340
PostPosted: Sat May 15, 2010 11:51 pm
Ok, now that I have removed the castings it seems that the springs are not showing alot of tension against the plungers. The adjusting screws have not been turned in years, so I put on some penetrating oil on them hopnig to make it easy to back them out, but I don't think its going to work. I need to buy a large screwdriver before attempting this.
PostPosted: Sun May 16, 2010 11:08 am
get a drill bit that is like 1/2 inch, drill a hole straight through it. Hit it with a torch, let it burn mostly out, then just pop the melted section out, and re-tap with a 3/4x8'' bolt and purchase two new kits! I think total cost for both sides was like $28?
Will make things much simpler!
1981 Hobie 16
1996 SeaDoo GTI
1999 Hunter 340
PostPosted: Sun May 23, 2010 8:22 am
Ok, I've drilled out the old screws and used a torch to remove the remants. They were really stuck in there. They probably have'nt been turned in 30 years. Not having a tap, I used a wire brush on a drill extension to clean the threads. The new screws won't go in much further than the old ones so I decided to put in some ss washers to stiffen up the springs. My local Hobie dealer reccomended putting some anti-seize lubricant on them. It should work just fine.
