It is currently Sat Aug 01, 2026 2:54 pm
 Post subject: Two 16's on One trailer
PostPosted: Tue Nov 22, 2005 7:06 am
We have added a second H16 to the "collection", aquired without a trailer.
We could build up a trailer for it alone, but when we travel to races we'll want both boats on a single trailer. My thoughts are why not make a trailer that suits both purposes, for day sailing at the local lake, when only one family member goes out to sail one boat. A set up where the bottom boat could be launched off a boat ramp and leave the one on top. We have one trailer that was modified for a catamaran and its load carrying capacity is not an issue.
Does anyone have ideas or have you seen a (for lack of better term) permanent two boat trailer? Is there one manufactured we could copy?
Fleet 297
PostPosted: Tue Nov 22, 2005 8:26 am
I haven't seen one, but what comes to mind might be possible.
Start with a regular boat trailer as most cat trailers do. Instead of adding cross bars that are just wider than the boat (wide enough to accommodate the rollers/cradles) make them wide enough to accommodate the width of the boat plus a vertical pylon on both sides. Then, add a second set of crossbars to the vertical pylons. I would probably add some logitudinal stringers to the top level for stability. Maybe even an extra pylon or two to the front trailer cross bar (This depends on how far forward the bottom boat sits on the trailer.)
Basically, you are creating a big box on top of a regular boat trailer. One boat will sit "in" the box and the other on the box.
Some concerns to be considered.
1) the lower trailer cross bars are strong enough to support the weight of two boats and the extra structure. Remember the weight will be applied at teh very ends of the lower crossbeams.
2) that you have enough access to the lower boat so you can ramp launch it.
If what I described isn't clear, please let me know and I will try to provide a sketch.
Nick
Current Boat
In the market
Previous boats owned
'74 Pearson 30
'84 H16
'82 H18 Magnum
St. Louis, MO
PostPosted: Tue Nov 22, 2005 11:06 am
Nick/John,
The box thing is a good idea, but you don't need to have the box out on the ends of the front beam (crossbar). You can make two support beams on the inside of the hulls to support an upper beam. this would make the box even stronger. You really only need the back crossbar beams to be wide enough for the boat to pass through.
I think the maximum legal width is 8.5 feet??
It would also be easier to get cradles that pivot on the back so that they will be at a good angle when trying to loat the top boat. Of course, rollers work. I would get really wide rollers so you son't be limited to one specific boat on top. I have my single trailer set up so that any 14-20 foot boat will fit on it. I plan on making a box like Nick suggested and I'll use big rollers on top..
Don't forget that if you are double stacking, you have to figure out what to do with the masts. Typically, when I double stack, the masts go on after the top boat is tied down and they go between the boats.
Dan
PostPosted: Fri Dec 02, 2005 2:28 pm
You don't need any additional structure other than a double mast crutch at the front of the trailer. In the past we traveled to many regattas with stacked H-16s.
First, step your mast and tie the boat and mast down as ususal. Then a couple of 2x4s nailed together, with carpet for padding, cross the trampoline near the front and rear crossbars of the bottom boat. Add bumps to the outside of the wooden cross bars to prevent side to side drift. You will need to build the front stack up on each side to allow the wooden crossbars to clear the trampoline hump near the front cross bars. Add a mast crutch to the rear wooden cross bar.
Step the mast on the second boat. Remove the mast by detaching the wires at the mast tang, stack the boat on the top of the first boat after you have tied down the second boat's mast. Tie the top boat down and off you go.
PostPosted: Fri Dec 02, 2005 4:46 pm
Hammond's description of stacking 16's is shown in a photo in Phil Berman's book, "Catamaran Sailing From Start To Finish", on p. 199. I can't say from experience it works, but the photo supports Hammond's simpler method. If you're concerned about the weight pressure on the bottom boat's hulls, then consider adding another roller to each point of contact.
PostPosted: Sat Dec 03, 2005 6:32 am
The best of both worlds - a double-stack trailer w/ a double stack on top:
Notice that the top two boats are stacked on themselves w/the 2x4 method.
