It is currently Sat Jun 20, 2026 11:23 am
 Post subject: Magnum wing question
PostPosted: Wed Jun 23, 2010 6:24 pm
On the rear crossbar my wings have a stud only on port side and a U shaped bracket on starboard that covers the slot to feed the tramp in, along with a stud.
Is the slug for the starboard side larger, all 4 new stud kits I bought are marked short slug?
 Post subject: Re: Magnum wing question
PostPosted: Wed Jun 23, 2010 6:40 pm
I think my starboard slug is a little longer. I will check tommorow and make sure.
PostPosted: Wed Jun 23, 2010 6:43 pm
I purchased my magnum wings used so I do not have the C shaped brackets on the crossbars. Yes the one rear slug is longer due to the clearance in the track. I use a stainless washer between the crossbar and the wing arm so not to chew up the crossbar when I rotate the wings up. I also use bolts instead of pins to hold them down as it stiffens the wings to the boat.
1987 Hobie Holder 20 #273
dale.vanlopik"at"att"dot"net
