It is currently Fri Jun 19, 2026 7:46 pm
 Post subject: Daggerboards????
PostPosted: Fri Jun 25, 2010 7:08 am
I purchased an 1987 Hobie Cat 16 this morning for $450. Nice boat in decent shape and can't wait to get it rigged and sailing. In all the years I have been watching Hobie sailing around my area I have never seen a dagger board being used. The original owner told me that they were critical to the upwind performance, but rarely used. I sail in open water so should I use the daggerboards or leave them in the garage? Thanks Andrew
 Post subject: Re: Daggerboards????
PostPosted: Fri Jun 25, 2010 4:22 pm
Are you sure it is a H-16 and not a H-18? I was not aware of any H-16's that have daggerboards.
Thanks!
Eric Weller
Eric Weller
2006 F18 Capricorn
1980 H16
Keep the pointy side up!
PostPosted: Fri Jun 25, 2010 7:37 pm
If you have a 16 your boat will not have dagger boards. If you have a boat with dagger boards, it is not a Hobie 16. Maybe an 18 as stated by Mr. Weller. Or something else perhaps?
'88 Nationals Blue
Hobie Alter Signature Model
Sail #11
Hobie Mirage Classic
PostPosted: Fri Jun 25, 2010 7:38 pm
Hobie 16 does not have dagger boards, they have asymetrical hulls. if you have dagger board slots then you have an 18
PostPosted: Fri Jun 25, 2010 8:12 pm
Regardless of what type of boat you have, if it has daggerboards, then you need to use them - you won't be able to go upwind without them.
As others have said, if it has daggerboards, it is definitely not a Hobie 16.
PostPosted: Fri Jun 25, 2010 8:22 pm
what i would do is either try to find out what model it is om the boat itself, which you might not be able to do because the stickers/plates have become too worn to read, as is the case with mine, or just measure how long it is and go from there. if the reason you thought it was a 16 was because it said 16 on the sail, it might just have the wrong sails on it.
'81 Hobie 16 #53 Cat Fever blue hulls
PostPosted: Fri Jun 25, 2010 9:55 pm
If the trampoline is elevated off the hulls, it's a H16. If the trampoline is flush with the hulls, them it's an H18...providing it's a Hobie at all.
Happy Sailing,
David
PostPosted: Sat Jun 26, 2010 5:21 am
You might want to check the first three characters of the hull VIN number to confirm it's a Hobie.
http://www.hobiecat.com/support/index-sail.html
Southwest Hobie Island Club
PostPosted: Mon Jun 28, 2010 5:17 am
I stand corrected. The original owner knew very little about the boat. I knew it was a Hobie and wrongly assumed it was a 16'. It is actually an 18' which makes the deal even better. I ended up paying the original owner $500 as he included a decent trailer and a beach dolly. The sails look to have minimal damage and the tramp has a few years left it in. Thanks for the help. Image
PostPosted: Mon Jun 28, 2010 11:21 am
You WILL need daggerboards for this one !!!
Happy Sailing,
David
PostPosted: Mon Jul 19, 2010 6:11 am
Did you find some daggerboards for your H18? Where are you located?
I've got 2 that are in decent shape. email me at [email protected]
Also, I've got a bunch of other misc parts as well.
