It is currently Tue Jun 16, 2026 10:13 pm
PostPosted: Wed Jun 30, 2010 2:31 pm
Okay I am finally making my Hobie 14 a turbo YAY!!! But the only problem is that I think I need a dolphin striker if I am getting a jib but I am not sure and everyone I have asked has said no, but just to make sure I wanted to ask the Hobie Community.
Please Reply
Captain Hook
PostPosted: Wed Jun 30, 2010 3:12 pm
Yes. That's why the dolphin striker retro-fit kits were sold with the jib kits.
Especially true if you plan to add a trapeze as well.
PostPosted: Wed Jun 30, 2010 5:23 pm
Okay so I guess it is kind of important because I am also putting up trap wires tomorrow and the jib. But also do you know the reasoning why I need one.
Captain Hook
PostPosted: Wed Jun 30, 2010 5:25 pm
Captain Hook
Because the front crossbar will collapse if you don't?
The dolphin striker turns the front crossbar into a truss, capable of supporting the increase in downforce caused by the addition of a jib and trapeze.
PostPosted: Wed Jun 30, 2010 9:13 pm
You need one? I got one! I also have a comp tip mast, a set of rails, and two of the hardest most solid uglly ass hulls you've ever seen.
Located in Iowa.
cw
PostPosted: Thu Jul 01, 2010 1:41 pm
wait are you saying you have an extra dolphin striker because I need one really bad but I am located in CT
PostPosted: Thu Jul 01, 2010 1:58 pm
I do, but If I am selling it away from the rest of the parts I have, youi'd be better off (price wise) to go on saltydogmarine.com and get one there.
PostPosted: Thu Jul 01, 2010 2:04 pm
do they have one specifically for a hobie 14
PostPosted: Thu Jul 01, 2010 2:59 pm
will a hobie 16 dolphin striker work?
PostPosted: Thu Jul 01, 2010 3:27 pm
The 16 dolphin striker is to wide out of the box. But if you are handy you could cut it down to make it fit..
A little tap and die work and some mild bending would be required.
www.thehobiewayoflife.com
PostPosted: Thu Jul 01, 2010 4:36 pm
Striker kit: 80200010 $93.75
The post and rod from a 16 will not work... those parts would also require a new step, so lots more money that way.
PostPosted: Mon Jul 12, 2010 7:32 am
I would like to make my 14 turbo as well. What is the cheapest way around this? $680 + sail is a little steep for a $600 hobie. It would need to be safe and complete
but I it does not need to be new and/or pretty. Any ideas on interchangeable parts so that i could broaden my used parts search? thanks
PostPosted: Mon Jul 12, 2010 11:01 am
The dolphin striker rod and post from a Hobie 17 can be used on a 14 with a little modification - mostly the post just needs to be cut down. You'd also need a new mast step casting, though.
PostPosted: Tue Jul 13, 2010 9:02 am
whoa Matt...now that'd be cool !
do the Wave and 14 share the same mast extrusion?
no more worries about tearing up the (mast) base and step from over-rotating...although I suppose if you've added the (mast) rotation arm you'll accomplish the same thing
none the less, would be neat to allow a fully rotational mast (along with shrouds attaching at the deck lip) 8)
Sheet In...Max Out
www.fleet297.org
PostPosted: Tue Jul 13, 2010 9:14 am
You misunderstood what I said, John - I'm not suggesting you use the same mast step system as the 17. In fact, to convert the 17 dolphin striker post on a 17, you cut off part of the threaded end so you can thread it on to a new 14/16 mast step casting. The original 14 mast step castings are solid - no hole for a dolphin striker.
I believe the Wave and 14 masts are the same extrusion, but Matt M. would have to confirm that.
If you want shrouds attached to the deck lip on a 14, get one of the new Euro boats. I'll live with mine attached to the sidebar for a long time before I shell out the €€€€€ they want for new boats.
