It is currently Sat Jun 20, 2026 1:13 am
PostPosted: Wed Jul 07, 2010 11:15 am
Wings have been added to my 1981 hobie 18 and also upgraded 3 wide harken mainsheet block set up. My question is this, when operating the main sheet from the bench, the angle causes the main to cleat to easily , I would like to have the main sheet "live" without cleating, how do you adjust angle to match sitting on bench?
PostPosted: Wed Jul 07, 2010 11:17 am
Harken wedge blocks.
harke n wedges Fairleads and
eyestraps designed specifically for each
Cammatic model, the wedges put the
Cammatic on a 15 degree angle for ease
of cleating or releasing. The fairleads are
molded into a replacement base for each
Cam-matic. The eyestraps are designed
to be held in place over the cams by the
mounting screws.
Wedge Kits
H145 (H150 & H365)
H297 (H423)
WIRE FAIRLEADS
H298 (H150 & H365)
H284 (H423)
EYESTRAPS
H137 (H150 & H365)
H201 Low (H150 & H365)
Rich Vilvens
F-18 5150
PostPosted: Wed Jul 07, 2010 11:41 am
napaboyg wrote:
how you adjust angle to match sitting on bench?
There are adjustment screws on the sides of the block. The whole jaw assembly can pivot. Loosen a screw on each side. Slide the assembly to the desired position and re-tension the screws.
