It is currently Tue Jun 16, 2026 3:20 am
PostPosted: Thu Jul 15, 2010 10:25 pm
Hi all
The bottom rudder gudgeon on my hobie 16 broke, followed by the top gudgeon breaking, pulling out of of the gudgeon screws from the hull. I was on a down wind run with a long distance to travel before could beach the boat. I sailed in on one rudder, with the departed rudder and cross bar trailing behind the boat.
A few questions:
Is there a back plate which the gudgeon screws go into?
I would like to avoid cutting a hole in the hull to put a back plate or other material in place for the gudgeon screw. I was thinking of drilling the current screw hole to a larger diameter, putting a stainless steel stud with a 90 degree bend into the hull and using epoxy to hold in place. The stud would be machine threaded. I would use a nut fastened to the stud to hold the gudgeon in place.
I know that I am not the first hobie owner to face this issue. Ideas?
thanks. Shane
PostPosted: Sat Jul 17, 2010 9:53 am
There is an aluminum plate that's glassed into the transom. The gudgeon bolts are threaded into it.
PostPosted: Sat Jul 17, 2010 8:18 pm
If you drill a slightly bigger hole, you should be able to re-tap the threads and either use a heli-coil to make it the same size hole (not really sure if a helicoil will take the stress though) or use a larger bolt.
Good luck.
Why did I sell my 16?
PostPosted: Sat Jul 17, 2010 9:50 pm
thanks. I'll try re-drilling
PostPosted: Mon Jul 19, 2010 6:36 am
Drill & tap the hole up one size to 1/4-20 if there is enough material remaining. (The current screws are #12-24).
Or, purchase the new one-piece gudgeons. Then you can proabably skip the damaged hole and relocate a new hole nearby.
PostPosted: Mon Jul 19, 2010 9:55 pm
Ok, I have ordered the one piece gudgeons. My boat is a 1976 model. The hole pattern doesn't line up with the one piece gudgeons? Do i need to drill all new holes and plug the old ones?
shane
PostPosted: Tue Jul 20, 2010 11:32 am
You will elongate the holes in the casting to fit.
