It is currently Mon Aug 03, 2026 5:56 pm
 Post subject: bend in comptip
PostPosted: Wed Aug 04, 2010 4:53 pm
I had a chance to pick up a free mast and this mast has a bend in the comptip. Not the aluminium. Anyone have any experience with this happening? Can sun/heat and a poor storage position cause the comptip to sag? What is the correct way to store a comptip mast? I think the guy had it laying in his yard for years. Any chance of fixing it? Its about a 1/2 to 1 inch curve. Thanks
 Post subject: Re: bend in comptip
PostPosted: Wed Aug 04, 2010 5:10 pm
Which way does it curve? if it curves toward the luff track then it's a-ok.
1990 "Formula 1" H16 (# 009)
PostPosted: Wed Aug 04, 2010 6:02 pm
Bends off to port. Bend starts in the middle of the comptip section. I think it's hosed.
PostPosted: Fri Aug 06, 2010 9:14 am
I have no experience with this but if you put a little pressure on it in the opposite direction, then take a heat gun and warm the area around the bend, I'm thinking if you warm the plastic slightly it may soften enough for you to straighten it out??
PostPosted: Fri Aug 06, 2010 11:41 am
Comptips are gelcoated fiberglass, not plastic, so I doubt that would work.
PostPosted: Fri Aug 06, 2010 4:02 pm
Comptips are heat cured epoxy if I'm not mistaken, so heating might work.
Are there any stress cracks? If not, sail it until it breaks.
Sail Revolution
Join us on our new FB Page!
Last edited by Sail Revolution on Fri Aug 06, 2010 5:04 pm, edited 2 times in total.
PostPosted: Fri Aug 06, 2010 4:52 pm
Now I feel really stupid! :oops: :?
PostPosted: Fri Aug 06, 2010 5:00 pm
Good thoughts here..Fiberglass is a short term for 'fiberglass reinforced plastic'. I learned that epoxy and polyester are just two different kinds of reinforcing plastic and epoxy has a lower melting point and deforms easier than polyester. I'm gonna take a queue from Roy and put it in the sun with a brace under the bend and weight the end. See what happens. In the meantime I will keep an eye out for a comptip. thanks,,
PostPosted: Fri Aug 06, 2010 6:01 pm
Here is a picture of my white formula comptip with the gel coat cracked off the fiberglass. Pretty plain to see the fibers really. Maybe it's heat cured epoxy though.
PostPosted: Fri Aug 06, 2010 6:46 pm
I would do as others have said...flip it over, put a little weight on it, and let it sit bent the other way for a while. We see this occasionally with composite windsufing masts. If someone leaves the sail rigged on the mast for too long (like at a rental where they keep the rigs set up for months at a time) the mast will take a set. The cure is to spin the mast 180 degrees and re-rig so it bends the other way. The fix should be the same for a fiberglass comptip.
