It is currently Sun Jun 21, 2026 10:27 am
Post new topic Reply to topic  [ 41 posts ]  Go to page 1, 2, 3  Next
PostPosted: Wed Aug 25, 2010 6:07 am
I am planning to add a spinnaker to my 16. I found a spinnaker sail that came from a 24ft Seafarer; Does anyone know what the sail dimensions are for a spinnaker on a H16?
This one's probably over sized but I'm not sure where to start. Any input on size ranges would be very helpful.
Thanks in advance!
'81 H16
PostPosted: Wed Aug 25, 2010 7:16 am
A spinnaker for a monohull is entirely the wrong shape for a catamaran.
Most monohull spinnakers are symmetrical and full and meant for sailing dead downwind. Catamaran spinnakers are assymetrical and flat and meant for VMG reaching at ~45 degrees apparent wind. They're more like a large jib sail than a conventional spinnaker.
What you have is completely useless on a Hobie 16.
The Hobie 16 spinnaker is quite small.
PostPosted: Wed Aug 25, 2010 7:17 am
My buddy just put a spinnaker on his boat. I think he said it was 12 or 13 meters square. We're having a blast! He is already talking about a larger one now.
PostPosted: Wed Aug 25, 2010 8:41 am
This should get you started in the right direction.
http://www.catsailor.com/forums/ubbthre ... ber=179150
PostPosted: Wed Aug 25, 2010 9:04 am
...and this is exactly why I come to the forum first. MBounds, you are the man; Sunvista, you give me hope; Tchilds, the devil's in the details.
THANKS to all!
'81 H16
PostPosted: Wed Aug 25, 2010 12:41 pm
I think the H16 spins are typically smaller for a reason. The mast tang is just pop riveted into plastic with the comp tip. If you have an older all alum mast you're golden.
PostPosted: Wed Aug 25, 2010 12:51 pm
I do actually, I have the one piece extrusion. WooHoo.
Have you (or anybody) seen or heard of The Hooter: http://www.catsailor.com/bestof_articles/Hooter.html
Thoughts? Opinions? Concerns?
'81 H16
PostPosted: Wed Aug 25, 2010 2:24 pm
Saw one on a H14 a couple years ago. Don't remember much detail though.
PostPosted: Thu Aug 26, 2010 5:57 am
I double checked the spinnaker size. It's 128 square feet. Everything is totally home grown. He made it with an industrial sewing machine and a $300 sail kit. The rest was modeled from the cat sailor link above, the Hobie Europe instructions and a lot of scientific guesswork (trial and error). Boom from a sawed off wind surfer mast. Piece parts (spin lock cleats, ratchet blocks, sheet rope etc) all begged, borrowed and purchased. We had a Hobie Tiger and a Nacra F18 to look at so we weren't flying totally blind.
PostPosted: Thu Aug 26, 2010 9:03 am
Thanks Sunvista! Sound's exactly like the process I am engaging! One bummer is that a couple of years ago I "freecycled" a windsurfer that I had received via freecycle myself. Would've, could've, should've.....
'81 H16
PostPosted: Wed Dec 08, 2010 9:12 am
Jman6631 did you put together a DIY Spinnaker setup for your Hobie 16? I would like to try and do the same thing. If so, please tell us how? Exact sail size too.
Did you go with a windsurfer mast for the pole?
I'm eager to add on to my Hobie 16
Mike
Mike
Pearland, TX
1990 Hobie 16
http://feidler.blogspot.com/
Member of Surfside Sailing and Hobie Fleet 33
http://hobiefleet33.com
PostPosted: Wed Dec 08, 2010 10:33 pm
Luff = 19.5 ft
Foot = 8.75 ft
Leach = 17.25 ft
8)
Happy Sailing,
David
PostPosted: Thu Dec 09, 2010 7:14 am
DavidBell47 wrote:
Luff = 19.5 ft
Foot = 8.75 ft
Leach = 17.25 ft
8)
Thanks David,
I found the Hobie 16 Spinnaker on catsailor at the following sizes:
Luff = 21.5'
Foot = 9'
Leech = 18.7'
2' longer luff? I wonder why the difference. :?:
Mike
Mike
Pearland, TX
1990 Hobie 16
PostPosted: Thu Dec 09, 2010 10:08 am
MG dimension is critical.
Sail Revolution
Join us on our new FB Page!
PostPosted: Wed Jan 05, 2011 4:49 pm
Do You have a MG Dimension? What is a MG Dimension? :oops:
Also, any one now what size and length the lines are for a midpole snuffer system?
Halyard/dousing line (loop)?
Tack Line?
Spinnaker Sheet (Loop)?
Would 40mm carbo and auto ratcheting blocks be suitable for the sheets?
What size blocks for the halyard & tack lines?
I'm gathering all my blocks now. I just purchased the aluminum pipe that will be my pole.
Mike
Pearland, TX
1990 Hobie 16
