It is currently Sun Jun 14, 2026 5:07 am
PostPosted: Tue Aug 31, 2010 1:40 pm
Noticed that the nuts on the bottom of the turnbuckle were midway on the threaded shaft which did not look right to me. Can anyone check theirs and let me know if the nuts should be up against the turnbuckle or all the way down against the v-frame base?
Also noticed that the rear aka has 2 pegs on the curved part of the arm. The ama bungis on the lower one. Is the upper one Hobie thinking ahead in case the bungi cord stretches so there is a tighter connection between the aka and ama? Just like to know what everything is for.
Fyi if it helps anyone - I noticed that the rear pulley system that is attached the lower right side of the kayak with 3 bolts has one bolt below the waterline. I took the bolts out and added a rubber washer to the lower 2 as I noticed that a small amount of water was getting in there.
Thank you all - this forum has been a great help.
Jim
Long Island, NY
2010 TI
PostPosted: Tue Aug 31, 2010 2:29 pm
The nuts should be up tight to the turnbuckle. It's the "lock" nut to stop it from turning. If you think it turned, you can adjust it so the mast reefing spool doesn't contact the hull. I try to keep the space as small as possible, without touching, so the reefing line can't easily slide under the spool.
PostPosted: Tue Aug 31, 2010 3:08 pm
thank you Bob - I've read a lot of your posts so am honored you have taken the time for a newbie. I will check that spacing out
Jim
Long Island, NY
2010 TI
PostPosted: Tue Aug 31, 2010 3:27 pm
Almost 4 years ago, I was newbier (??) than you, so Welcome and Enjoy!
PostPosted: Wed Sep 01, 2010 1:35 am
My turnbuckle nuts were both loose until I had the dealer tighten them correctly. I didn't realize they had upper nuts as well, as they are up out of sight under the deck. Once tightened correctly, they haven't come loose again.
Mitch
    2010 Tandem Island
    2010 Revolution
My sailing blog
Our sailing videos
PostPosted: Wed Sep 01, 2010 5:31 am
maybe something for the TI checklist then?
Jim
Long Island, NY
2010 TI
PostPosted: Thu Sep 02, 2010 11:50 am
marjim,
It sounds like it should be added to the preflight checklist. Especially items around the mast area where there's a lot of stresses. From previous posts, if you tighten them correctly, they should never come loose. But for added assurances, I'm thinking of adding a few drops of "green" Loctite.
c2y
PostPosted: Thu Sep 02, 2010 5:15 pm
marjim, it's in the Hobie Island Checklist, see "V-Frame turnbuckles loose".
cliffs2yak, I've been wondering if we should have a separate "Preflight" checklist though. Kayaking Bob has posted his checklist, which is quite thorough, as he tends to push his Islands pretty much "to the max". We could ask Bob to post a new thread on his presail checklist, and 'bump' it occasionally so members will find it, or I could add it as a separate table to my Checklist webpage.
Any thoughts? Bob?
PostPosted: Thu Sep 02, 2010 6:15 pm
captain-max,
Your website is looking good and thank you for your efforts especially since it's helping many of us.
c2y
PostPosted: Thu Sep 02, 2010 6:26 pm
My pleasure mate. I've gotten so much from the members on the forums here, that it was my chance to contribute a wee bit back. 8)
PostPosted: Thu Sep 02, 2010 6:39 pm
thanks capt-max - the shortcut was a great link.
Jim
Long Island, NY
2010 TI
PostPosted: Fri Sep 03, 2010 3:36 pm
Only one nut found on my 2007 AI brace. The bottom one.
Please check me on this, folks.
The Wind Is Your Friend...
PostPosted: Fri Sep 03, 2010 3:38 pm
cliffs2yak wrote:
marjim,
c2y
Howzit Cliffs -What's the green version? Usually Blue or Red is recommended.
PostPosted: Tue Sep 07, 2010 11:11 am
Nohuhu,
The green Loctite is the less viscous version of Loctite which is designed to seep into the treads without requiring disassembly. My locking nuts on my turnbuckles seem pretty tight after a few outings and don't want to mess with it very much at the moment. And so I'm opting to use the green Loctite for some quick and easy assurances. Eventually I'll have to do a maintenance breakdown and will disassemble, clean, and use some blue Loctite.
cliffs2yak
PostPosted: Thu Sep 09, 2010 1:50 am
Maybe a dumb question.... Do Hobie Loctite at the factory???
If not why not?...surely they should do this...I see lots of issues with loose bolts and I am waiting for delivery of mine.
If it is such a problem then I will take every screw out and loctite it if it has not been done at the factory. I don't want any surprises out off shore. Had enough of those already to last me a lifetime!
Sail it like you stole it!
