It is currently Tue Aug 18, 2026 11:50 pm
 Post subject: Git Rot Substitude?
PostPosted: Thu Sep 16, 2010 10:00 pm
Hello,
My H16 has a huge softspot in from of the front crossbar post (usual spot) and here in canada I cannot find any place that sells Git Rot. Will any other epoxy do the trick? or MUST it be Git Rot?
'72 Hobie 16
with
#56 Gonzo Nationals
 Post subject: Re: Git Rot Substitude?
PostPosted: Fri Sep 17, 2010 4:21 am
I am in the same boat, no pun intended.
Marc...
PostPosted: Fri Sep 17, 2010 5:38 am
janek.w wrote:
Hello,
the Git Rot kit is cool because it comes with a syringe, but yes any other resin (i.e. polyester or vinylester) will work. Polyester is much cheaper than Epoxy resin.
these people dont ship to Canada?
http://www.jamestowndistributors.com/userportal/main.do
Sheet In...Max Out
www.fleet297.org
 Post subject: Re: Git Rot Substitute?
PostPosted: Fri Sep 17, 2010 10:51 am
Not just any resin.
Laminating resin so it is not brittle. Another nice thing about the Git Rot is the penetration quality. Thicker resins my not flow as well.
PostPosted: Sat Sep 18, 2010 10:15 am
West Marine ships to Canada. They also have a couple of stores in Canada.
Also, delamination can be a safety issue. That's not something I like to cut corners on.
Dave W
PostPosted: Wed Sep 22, 2010 9:25 am
I put my git rot in thr refigerator before use gives longer work time also dry hull area as much as possible drill holes and keep the rain off for a few days
