It is currently Mon Aug 03, 2026 6:32 am
Post new topic Reply to topic  [ 22 posts ]  Go to page 1, 2  Next
 Post subject: Class legal?
PostPosted: Fri Feb 03, 2006 1:12 pm
Just wondering if 16-1 is now legal for the Hobie Tiger. I reviewed the rules and think that it is. I just want to make sure I'm not missing something?
I know it's legal in the F18 rules.
Mike Hill
Mike Hill
Hobie Tiger #1520
 Post subject: ?
PostPosted: Fri Feb 03, 2006 2:18 pm
Mike:
Did you use to race in Texas in the late 70's, early 80's?
Doug Snell
Hobie 17
Soon to be Nacra A2
www.tcdyc.com
PostPosted: Fri Feb 03, 2006 2:49 pm
Mike, from the Hobie Tiger Class rules:
3.3
Mainsail downhaul purchase shall not exceed
16:1 and may be rigged in any manner.
Greg Thomas
Hobie Factory Team
PostPosted: Sun Feb 05, 2006 10:54 pm
3.3
Thanks Greg,
I was just confused because I thought it was 12-1 last year max and I didn't remember seeing anything about the change.
And Doug I didn't learn how to sail until about 93.
Mike Hill
Mike Hill
Hobie Tiger #1520
 Post subject: Wrong Mike Hill
PostPosted: Sun Feb 05, 2006 11:51 pm
Mike:
OK. Sorry. Check out our site sometime. The are a few Tiger sailor on our site. Chris Green is now the commodore for Div 6. Register and join forum.
Doug Snell
www.tcdyc.com
PostPosted: Mon Feb 06, 2006 12:16 pm
Mike:
It did change from 12:1 to 16:1. I still have mine set up as 12 to 1 and am planning on changing it as soon as I figure out how I want to rig it. The 12:1 that I have right now did not require any more holes drilled into that mast, but we do have to preload it.
Later,
Dan
PostPosted: Tue Feb 07, 2006 10:22 pm
Dan DeLave wrote:
Mike:
Later,
Dan
Dan,
I can heartily reccomend an 8:1 with 2:1 cascade (making 16:1) for the downhaul. We copied this shamlessly from Tomko. We used the inverted heart shape shackle that came with the 8:1 downhaul. Then added a jam cleat about 6" up from the base on each side of the mast.
From this jam cleat we ran spectra line up and over the outside pulley on each side at the clew (using the two double pulleys that came with the original 8:1). After turning over the outside block a single block is tied to the end of the spectra. The 8:1 is then threaded from the swivel cleat through this block, back to the base, back up to the other spare pulley on the double block, back to the centre block on the base and repeat in reverse order on the other side of the mast.
We then tricked ours out a little further with spinlocks instead of cam cleats. Much better than the 12:1 or 16:1 rigged using those outlandish fixed turning blocks that hobbie puts way up the mast. We took those off and covered the rivet holes with black stickers.
Chris.
2008 Hobie Tiger
PostPosted: Wed Feb 08, 2006 6:58 pm
are you sure this is 16-1. I have mine like this, I think, and it is only 12-1. count your purchase lines. You are not doubling the whole 8-1, just the outside 2-1 on each side. If I'm wrong please correct me so I can change mine. Works pretty good anyhow. Rick
PostPosted: Thu Feb 09, 2006 1:13 am
8:1 with a 2:1 cascade = 8*2 = 16:1. I run mine as a 4:1 cascading into another 4:1. Similar deal with most of it running under the trampoline.
Michael
PostPosted: Thu Feb 09, 2006 8:33 am
Thanks, in the above example you are not doubling the entire purchase because the 2-1 on the outside block becomes part of entire purchase. It does not double it. If you don't run under the tramp as you have suggested, you run out of room, even with preloading, real quick. I'll quit at this, since I have been known to be wrong, but if you draw it as described earlier, I think you'll see the 2-1 has to be independent of the 4-1 to double it. In essence here it is doubling the middle 3 blocks (6-1). Spring is almost here and I can quit trying to figure out the boat and sail it. Rick
PostPosted: Thu Feb 09, 2006 9:41 am
Michael
Tiger Mike, I'd be interested in seeing how you did the 4:1 cascading into another 4-1. Pictures would be great but a description would be appreciated.
I also agree with Chris that the system previously described was definitely a 12-1.
Mike Hill
Mike Hill
Hobie Tiger #1520
PostPosted: Thu Feb 09, 2006 12:13 pm
Here is the information (drawing) that I "grocked" about flumpmasters post.]http://members.aol.com/ddelave/sailing/Downhaul.jpg.
The black lines are my 12:1 system. Add the pink to the black and get a 16:1 system. I do not think that I can have that much line in there as I am running out of room with the dowhaul that I have. I may give it a look see though. I also use spinlocks for the downhaul system. They are great as it is easier to release these.
If you need more explaination I will be happy to give it.
Later,
Dan
PostPosted: Thu Feb 09, 2006 12:43 pm
Dan, on your black "12:1" system, what happens in the middle where the black lines seem to converge in a "V"???
Michael
PostPosted: Thu Feb 09, 2006 1:24 pm
Tiger Mike:
That is a double block with a becket that hangs off the sail. Both side tie to the same becket. I use the very small Ronstan high load blocks there and Vectron or spectra line for the inside arrangement.
The pink extensions would be two double blocks without beckets. They would hang from the upside down heart shackle that comes with the Tiger.
Dan
PostPosted: Thu Feb 09, 2006 2:27 pm
Dan DeLave wrote:
Tiger Mike:
Dan
I would have to see it to be sure however I suspect you have more than 12:1. The green lines alone are 4:1. It really depends on what other blocks are turning blocks or floating (trying to put 2 systems on 1 diagram is difficult too).
Michael
