It is currently Sat Jun 20, 2026 6:56 am
PostPosted: Mon Sep 20, 2010 8:25 pm
I am having trouble getting these hobie 18 hatch covers opened, I came open with difficulty, the other I cannot seem to get it opened. just bought the boat and I am getting it ready for the winter. Any advice????
Marty in Sask, Canada
Hobie 18sx
Hobie 16se
PostPosted: Tue Sep 21, 2010 12:50 am
Pair of pliers (handles in the cover) and a screwdriver for leverage does the trick for me.
H18 Newbie, Too heavy for the 14
PostPosted: Tue Sep 21, 2010 9:34 am
Lubricate the o-rings.
PostPosted: Tue Sep 21, 2010 8:54 pm
Got them off, a little lubrication, and some gentle tapping.
Marty
PostPosted: Wed Sep 22, 2010 7:05 am
Replace with screw-type from Murrays - so i've been told. Stock ones apparently cause local delamination due to flexing from force required to remove/replace.
6" flat for front, 4" curved for rear (if your boat rear hatches).
PostPosted: Wed Sep 22, 2010 8:16 am
The "stock" ones refered to are "pop-in" ports with a rope pull loop... old style. More recent H18s had screw in lids. All require o-ring lubrication to function correctly.
See a Hobie Dealer for replacements of either style.
http://www.hobiecat.com/support/dealers/search/
PostPosted: Wed Sep 22, 2010 8:21 pm
I have the screw in ones, what shall I lubricate with in the spring?
2001 18SX
PostPosted: Wed Sep 22, 2010 8:24 pm
Pool supply stores sell a water proof lube for O rings used say around the pool pump. I would coat the ring lightly now. Helps keep it soft and avoid cracking/dry rot.
1984 Hobie 18
PostPosted: Thu Sep 23, 2010 8:52 am
Avoid petroleum lubricants. These can damage some o-rings. Use a silicone lube.
PostPosted: Tue Oct 19, 2010 11:28 am
We store on a sandy beach...and the screw-type hatch covers (after appropriate lubing) still are unoperable after a couple days of storage.
The lube doesn't matter...I feel the grit of the sand gets in the threads and locks the covers. Fat bags become useless.
Does anyone have an idea that really works on a sandy beach?
PostPosted: Tue Oct 19, 2010 12:31 pm
Every boat in the club i have seen is left with the covers removed and the opening covered by a daggerboard on each side. The thought is that moisture will evaporate out of the open port and the daggerboard will keep most of the moisture out. If you did that then the sand wouldn't be a problem.
There are pro's and con's to everything and good arguments for each opinion. I have no idea if this is good or bad, it's just what i observed.
PostPosted: Tue Oct 19, 2010 3:25 pm
I thoroughly cleaned the threads and then sprayed on two coats of McLube Sailkote which I let dry for about 2 minutes before screwing the covers back in. It makes a significant difference but you will need to re-apply it every couple of weeks because it tends to wash away. I keep the can in my sailbox.
PostPosted: Wed Oct 27, 2010 5:24 pm
Thanks for the port cover tips.
Here is another for you; I got extra port covers. Take a hole saw and put a hole in the center for PVC elbows, a 90 & 45. a little screen and screw them in while the boat isn't being used. Ventilate the hulls and keeps it dry even in the driving rain. No sand & bugs either. Change them out to the flat covers and go sailing. Pictures available, just drop me a note.
1987 Hobie Holder 20 #273
dale.vanlopik"at"att"dot"net
PostPosted: Tue Mar 20, 2012 11:37 am
I have a 1983 Hobie18 and i'm searching the internet (with no luck) for the older style 6" porthole hatch cover (deck lids). These are the kind that pop-in or out and have the rope attached to them. If anyone is upgrading to the newer screw-in type let me know because i'd love to purchase your old pop-in covers if they are in good condition.
I know its better to upgrade to the screw in type but with two kids i don't have much time for maintenance if i want to sail this year.
Drew
PostPosted: Tue Mar 20, 2012 11:52 am
Drew
