It is currently Wed Aug 05, 2026 12:12 pm
 Post subject: easy fin repair
PostPosted: Sat Sep 25, 2010 1:56 pm
I purchased these boot patches for repairing turbo fins, I cut to size, cleaned area with wire brush per instructions peeled and stuck. It says they are pressure sensitive, the more you press the better they seal so I used my vise :D . Ater six trips still holding no peeling. I did one on the water and worked better than expected still sticking as well.
http://www.rubberbootbandage.com/index.html
 Post subject: Re: easy fin repair
PostPosted: Sat Sep 25, 2010 6:50 pm
I've used those those patches for my rubber boots but never thought about using them for my fins... They've held up good for me in the past. Thanks for the reminder. By the way, using your vise may have been just a little extreme :shock: !
PostPosted: Sat Sep 25, 2010 7:49 pm
I know, but it worked! :oops:
PostPosted: Sun Sep 26, 2010 1:54 pm
Looks like a good idea. I have been using Gorilla tape, but I have to change it every three or four trips. It comes in 2 x 5 inch strips, which would make it good for emergency hull repair also.
I'm right 98% of the time. The other 3% I don't worry about.
PostPosted: Mon Sep 27, 2010 5:07 pm
Hobie Team Member
Never thought of that Randy. Great idea.
so I used my vise
Maybe chew on it a while. :D :D :roll:
Roger
http://www.aldenofsunapee.com/
Image http://www.NEKF.com/
PostPosted: Mon Sep 27, 2010 6:38 pm
at almost 30 dollars a fin, it was worth a try. I put on new fins in the area they seem to tear as reinforcement, so far so good
PostPosted: Sat Oct 02, 2010 1:14 pm
I was looking at the Rubber Boot Bandage website, there's a page you can enter other uses for the patches. It's 1001 other uses for Rubber Boot Bandages on the bottom left side of the homepage. You should list your use for the fin repair on there. :idea:
