It is currently Sat Jun 20, 2026 9:07 pm
 Post subject: SAIL BATTEN TENSION
PostPosted: Wed Oct 13, 2010 8:23 pm
How do i know what batten tension i need for every wind condition. i see trentec drift gauges but i don't won't to buy them till i know how to use them. :?
 Post subject: Re: SAIL BATTEN TENSION
PostPosted: Thu Oct 14, 2010 3:58 am
I do not use guages, but then, I'm not racing either. I can tell you that in heavy weather, I don't use any batten tension at all, this moves the pocket as far forward as possible and flattens the sail (high gear). When it's a gentle breeze day I tension the battens as much as I can to move the pocket aft and increase the power (low gear). On days that are in-between I just guess and go somewhere in the middle between tight and loose. Seems to work for me, I'm just not serious enough about it to use draft guages.
1990 "Formula 1" H16 (# 009)
PostPosted: Thu Oct 14, 2010 8:30 am
You don't need gauges. Set them the same every time. They should be snug enough that they induce a moderate curve along the length of the batten pocket and there should be no wrinkles in the sail fabric.
Adjusting the batten tension for different windspeeds really has no significant effect on draft position or depth. Sail draft is affected primarily by the sail controls (mainsheet & downhaul) and the sail cut. Draft is also affected to a lesser extent by the taper of the battens. The batten tension should simply be set so that the sail fabric is pulled firmly and no wrinkles exist.
Running the battens loose in high wind is just asking to have a batten tip poke through the sail. You would be better off swapping a stiffer batten, but even that would have limited effects.
PostPosted: Thu Oct 14, 2010 7:53 pm
Thanks for the info. i'am not raceing either but i do have the need for speed :D and i' am some what new to the sport and i 'am trying to learn as much as i can. thanks again.
