It is currently Sun Jun 14, 2026 11:31 pm
PostPosted: Wed Feb 22, 2006 3:34 pm
Hi! any ideas on how to fix this? on my h18
The hole in the mast step has the thread completely worn of...
The hole is even bigger than the screw.
And the screew just wobbles about in there...without holding the teflon bearing in place...
Has anyone else experienced this?
The only thing I thought was take the mast step to a welder for him to fill the hole up and rethread it to the screew size
Any ideas welcome, Thanks
PostPosted: Wed Feb 22, 2006 5:34 pm
You could fill the hole w/ Marine-tex (clean it up real good w/acetone beforehand), then drill/tap a new hole.
Welding aluminum castings is very tricky.
PostPosted: Wed Feb 22, 2006 9:07 pm
If you are going to weld the Al/Zn casting you might as well buy a new one. These are not condusive to welding. If you want I can get into why. The marine-tex is a good idea. I would consider buying a new one or a used one from someone parting out thier boat. This is a pretty important piece of hardware.
Nick
Current Boat
In the market
Previous boats owned
'74 Pearson 30
'84 H16
'82 H18 Magnum
St. Louis, MO
 Post subject: What is marine-tex?
PostPosted: Thu Feb 23, 2006 12:54 am
Is it like the wite putty used to fill-repair hulls cracks?
I have found a web of marine tex but there is lots of products...what one are you talking about?
PostPosted: Thu Feb 23, 2006 1:15 am
Does anyone have a photo of the new 4 hole mast step?
How are the holes placed? On my actual crossbar the rivet holes are worn and the mast step and striker post end up getting loose and rising...
If the 4 holes are in diferent position to the 2 holes on the 2 hole mast step version It would help
PostPosted: Thu Feb 23, 2006 6:03 am
This is the stuff you want:
Comes in gray (almost black) and white.
PostPosted: Thu Feb 23, 2006 7:44 am
Pictures and replacement guide:
http://www.thebeachcats.com/modules.php?set_albumName=Hobie-18-Mast-Step&op=modload&name=gallery&file=index&include=view_album.php
 Post subject: New step casting
PostPosted: Thu Feb 23, 2006 10:54 am
Old style castings are not available.
The new casting requires the new post as well. This is available as a kit / assembly #60180011
The bearing screw threads directly into the top of the new style post which corrects issues of corrosion in the threads. The post passes through the casting, so there is no thread corrosion there. The casting has a much larger contact surface on the front crossbar and 4 rivet location marks. You can easily move the locations to avoid existing corroded holes from the old casting.
