It is currently Sat Jun 20, 2026 11:53 pm
 Post subject: Is this a good buy?
PostPosted: Sun Oct 24, 2010 12:43 pm
I am looking at a 1994 H16 that is in good shape with a trailer. The main has been repaired due to someone falling through it and the jib is a jib off an H18 that was trimmed down to fit and includes a roller furling. Tramp is good and the hulls are solid. I can get it for $1600, whats your thoughts. buy it or leave it.
 Post subject: Re: Is this a god buy?
PostPosted: Mon Oct 25, 2010 10:06 am
If thats the jist of it and nothing is wrong, get it.
PostPosted: Mon Oct 25, 2010 1:04 pm
If that's the one w 4 inspection ports, I'd offer lower or pass.
PostPosted: Mon Oct 25, 2010 1:42 pm
If it's a solid boat with no surprises, that's a smokin deal in my opinion. Especially if it comes with a good trailer.
:mrgreen:
1990 "Formula 1" H16 (# 009)
PostPosted: Mon Oct 25, 2010 2:35 pm
just make sure the hulls are solid ... and the year is correct ..any photos????
•Present boat -1998 Hobie 16 Solana Sails furling jib[/size]
 Post subject: Re: Is this a good buy?
PostPosted: Mon Oct 25, 2010 3:19 pm
http://pensacola.craigslist.org/boa/2020147266.html
This is the ad with pics.
PostPosted: Mon Oct 25, 2010 3:56 pm
Its in Pensacola Fl and he said it does have 4 ports. Why do you say that?
PostPosted: Mon Oct 25, 2010 4:25 pm
Ports are not good for structural integrity and they are a sign that repair work was done. Depending on the location of the ports you should walk away. If they are forward of the front pylons, forget it. Ports aft of the the rear pylons are okay.
PostPosted: Mon Oct 25, 2010 4:44 pm
the ad says a 1996....
the ports could be an issue... ask why he put them in.. and look for soft spot areas that might have been fixed.... and walk if the boat was ever painted....
and again make sure of the year....
PostPosted: Mon Oct 25, 2010 5:08 pm
They are in front of the pylons and yes it has recently had the hulls gel coated. He says the front ports are stuck also so they would have to be replaced he said. By stuck he probably means glued to hide repairs. The ad states a 96 but he said it was a typo. I guess I should walk away.
PostPosted: Mon Oct 25, 2010 7:32 pm
Definately walk away. This one has had a bad history I think. There are too many out there to buy someone elses problem.
'88 Nationals Blue
Hobie Alter Signature Model
Sail #11
Hobie Mirage Classic
PostPosted: Tue Oct 26, 2010 8:23 am
I was interested in buying it until I checked it out. 94 hulls w portholes infront of front pylons and behind rears, 80's tequila sunrise sail, h18 jib. No va.
PostPosted: Tue Oct 26, 2010 8:49 am
Good decision not to buy. I'm sure you want a boat that will last you a long time and be reliable. I seriously doubt you would have been happy with that one.
PostPosted: Fri Oct 29, 2010 2:16 pm
I looked at this too for a friend. I passed :(
Tom Whitehurst
PostPosted: Fri Oct 29, 2010 3:00 pm
Hints the reason he has been listing it for a while.
