It is currently Tue Aug 11, 2026 11:09 pm
Post new topic Reply to topic  [ 32 posts ]  Go to page Previous  1, 2, 3
 Post subject: Re: My pro Angler rigged
PostPosted: Sun Nov 07, 2010 7:57 am
Sifisto,
I have to ask, Can you share how were you able to rig your rear anchor trolley pulley so far back? I would like to do the same thing with mine. Thanks in advance.
PostPosted: Thu Jan 06, 2011 8:56 pm
I'm just viewing this now, sorry to get back to you so late. That rear anchor trolley is installed using a harken pulley system, with the holes drilled out to fit two bolts which mount to well nuts. There's no pressure on the system, so well nuts are fine. I fish all the time using this system in the spring, it has never failed. You also want the trolley to be set just above the water line, this allows your kayak to be more stable in chop. The higher the anchor trolley, the more you will get rocked around. just a heads up.
