It is currently Thu Aug 20, 2026 10:41 pm
 Post subject: Jib Kit for the Wave
PostPosted: Mon Nov 15, 2010 3:56 pm
Will a Jib Kit for the Wave give the boat more speed & performance? Is it worth the cost?
 Post subject: Re: Jib Kit for the Wave
PostPosted: Tue Nov 16, 2010 9:19 am
The jib is small, but fun to use. It can help a bit on a reach, but was never intended as a big performance booster. This was part of a set of accessories that can help train people on their use... jib, trapeze and spinnaker. BTW... The spinnaker is a bigger performance boost!
PostPosted: Tue Nov 23, 2010 4:52 pm
the jib on the Wave will make the boat point better and tack a little easier.
PostPosted: Fri Nov 26, 2010 6:58 am
This comes up every month or so.
The jib does NOT allow the boat to point higher. Unirigs will almost always point higher then a boat with a jib.
The Wave is very easy to tack and I doubt if the jib would make that any easier.
The jib might make the boat a little faster on a raech, however.
Jack Woehrle
Wave #100
H20 #287 "Tallahassee Lassie" (down in FLA)
