It is currently Fri Jun 19, 2026 1:44 am
 Post subject: Car Carrier for Outback
PostPosted: Sun Dec 12, 2010 2:29 am
Does anyone use a car carrier for their outback? If so which one? and Can you post a picture so I can see how it supports the hull. I've never seen one in a carrier, and would love to try one as its a hassle to get everything out of the kayak in order to tip it upside down to get on the car.
Cheers,
David2444
PostPosted: Sun Dec 12, 2010 12:15 pm
Carry upside down, and you will get better gas milage. Remember to tie both front and back of yak to steady the yak and not slide forward or backward.. Good Luck
PostPosted: Sun Dec 19, 2010 3:52 pm
I have a set of Thule racks, can you get them in the US? Have a set of cradles on these which I have had for some time with previous yaks. They are great as they keep the kayak extremely stable and if you haved any protruding mounts on the kayak sides the don't interfere with loading.
PostPosted: Mon Dec 20, 2010 12:04 pm
I use a Thule 887 Slipstream. I use it on an SUV, so the load/unload angle is pretty steep. One-man operation requires lifting one end at a time, and a piece of carpet or towel to protect the stern if you're on a hard surface or gravel. But overall, very easy to use - even by myself I can load/unload in under 5 minutes. Without the roller on the rack, I'm pretty sure I couldn't get it on top of the vehicle without a second set of hands. The kayak sits upright supported by four pads/cradles. Super stable even at highway speeds (properly strapped, of course). Most of my kayaking is within a few miles of home so gas mileage wasn't a major consideration for me.
PostPosted: Thu Dec 30, 2010 9:30 pm
I have a Slip stream also...I'm 62 with a Hernia...Not the easiest to get up alone....I Bought a 2nd hand Hullivator...The only way to go... No Sweat Now...Carry upside down & it will fit...Will sent Pics , Maybe someone can put them up
PostPosted: Fri Jan 07, 2011 8:15 am
hullavator is great carrier. little expensive but worth it.
John
PostPosted: Thu Jan 13, 2011 10:55 am
When we had a Sport and Outback in 2009, we used a Thule Hullivator. Pix can be found here.
Mitch
    2010 Tandem Island
    2010 Revolution
My sailing blog
Our sailing videos
