It is currently Mon Aug 10, 2026 6:19 pm
PostPosted: Sun Jan 23, 2011 9:17 am
Is there any reason not to leave this alone until spring ?
Thats my AI ... you can kind of make out the Ama's and the nose poking out to say "Brrrr", the hull has the factory top cover on it and then is rolled 3/4 of the way upside down on its side leaning on the garage wall. The X-braces are resting on closed cell foam.
I've dug it out a few times but I cant keep up ...
... plans were first to store it over winter in a friends' airplane hanger, when that fell through I was going to install some J racks on the outside wall of the garage but winter came sooner than expected. I could prolly find a place for the Ama's in the garage but not the hull.
For those that dont know, that white stuff all over it is called Snow, its a form of frozen water, Yes it does go away, but NO, you can't sail on it.
Alan W.
.. and a Hobie Outback SUV
PostPosted: Mon Jan 24, 2011 3:13 am
How big's your living room? :roll:
As to not being able to sail on snow, just give it time. I'm sure someone here will come up with a plan.... :lol:
PostPosted: Mon Jan 24, 2011 12:26 pm
How big is your living room
... prolly big enough but the sumbarine is in dry dock there this winter
Hmm ... over 100 views and no one can tell me if its OK to leave it in the snow ? or how about the cold - my truck said 3 deg this morning :shock:
I know its a damn shame to look at - and it should have been in my friends' heated hanger as I said. Im sorry AI ... may the rudder pin gods strike their wrath on my pin during the first sail of 2011
Alan W.
PostPosted: Mon Jan 24, 2011 1:19 pm
I am no expert on this but from everything I know about the plastic your kayak is made of the cold temperatures will have no permanent effect on the plastic. Cold temps will make it more brittle but that would only be a factor if impact loads were happening to the boat. I say just keep it where it is and don't let icicles hit it.
Once things start to thaw out you might want to make sure it doesn't collect water and put any odd loading on the boat.
I am guessing it may be awhile before it is in liquid water again :)
PostPosted: Mon Jan 24, 2011 1:58 pm
I'd be curious to see what Matt Miller has to say about this.
You'd have to think that the cold shouldn't be a big issue, and simply coming into contact with snow itself shouldn't be a problem.
I would think the biggest dangers would be the weight of the snow building up, and any ice, tree branches, or other firm things that might break and hit the boat while it's so cold, would cause the highest risk.
Surely the boat is strong enough to handle cold, and contact with snow. Right Matt? :)
PostPosted: Mon Jan 24, 2011 4:30 pm
Review the FAQ on winter storage.
http://www.hobiecat.com/forums/viewtopic.php?f=21&t=32883
As others have noted... impacts when cold are bad. Weight is bad, but cold by itself is not too bad. What I see that is an issue is the exposed plastics cooking in the UV... that is bad.
PostPosted: Mon Jan 24, 2011 6:04 pm
not a problem - we're due more snow tomorrow :D :roll:
... I'll get it dug out and properly stored this weekend
Alan W.
PostPosted: Tue Jan 25, 2011 7:20 am
send it down here on a winter vacation. We'll keep it warm and flexible for you. It's 81 deg. right now...and all our ice stays confined behind closed doors and inside drinking glasses and coolers. As it should!
Last weekend:
(there. Did that help warm you up some?)
http://2gringos.blogspot.com/
PostPosted: Tue Jan 25, 2011 9:26 am
Was down your way on Grace Bay at the beginning of the month. Darn gate agent wouldn't let me board with the AI tucked under my arm so I had to borrow a rental
Alan W.
PostPosted: Tue Jan 25, 2011 4:43 pm
Ha ha, I know perzactly where you took that photo.
PostPosted: Tue Jan 25, 2011 6:46 pm
Snow, never heard of it. I think you blokes are making it up. Next you'll be telling us is that it falls from the sky as flakes. :roll:
Those photos look nice fellas. Pity about that oil slick Gringo. Next you'll be telling us is that it's coral. :roll:
cron
