It is currently Thu Aug 06, 2026 9:47 am
PostPosted: Thu Jan 27, 2011 5:40 am
]Been playing with some new software for displaying my sidescan sonar data. It creates geo-referenced overlays in Google Earth.
This is a small run up Burns Bay off the Lane Cove River as a test. The images are about 10MB total to download. The bigger run up the river was about 180MB. Some people may like to download that much. I'll play more with the software to make it a bit smaller.
You’ll need Google Earth installed, then click here-
http://www.pixel-landscapes.com/Sidescan/SonarTRX-R00005-20110127-074135/doc.kml
(click Open. Google Earth should load and zoom to the correct area)
Homebush Bay Shipwreck (Added 16/feb/2011)
http://www.pixel-landscapes.com/Sidescan/Homebush_Shipwreck/SonarTRX-R00010-20110215-095820/doc.kml
Meadowbank Railway Bridge (Added 16/feb/2011)
http://www.pixel-landscapes.com/Sidescan/MeadowBank%20Railway%20Bridge/SonarTRX-R00010-20110215-101009/doc.kml
If look at Temporary Places on the left hand side you should see a place called SonarTRX-R00005-20110127-074135. The blue lines on the sonar images can be removed by deselecting Areas. This will make the sonar images less cluttered and easier to see. The transparency of the images can be changed with the slider bar directly below the Places pane on the left.
If you look you can see the photographs of the moored boats in the Google Earth photo and the sonar images showing the bottom with mooring chain markings in the mud/sand. In some cases you can also see part of the hull in the sonar images. Obviously the boats move about a little due to tide and wind.
The watermarks are because I'm using a trial license at the moment while waiting for my USB dongle thing to turn up.
Now I'm off to bed....
PostPosted: Thu Jan 27, 2011 6:20 am
Hobie Team Member
absolutely incredible the technology out there....
Keep away from Destin Florida though please....
Cant have all our fishing spots getting posted on Google Earth.
:o
Don't lead me to temptation, I already know the way.
Syn
PostPosted: Thu Jan 27, 2011 6:46 am
What brand/model side scan did you use?
What software did you need to import the scans into Google Earth?
Is there an Internet site which explains the technique?
TIDALWAVE
PostPosted: Thu Jan 27, 2011 1:30 pm
TIDALWAVE
The software is called SonarTRX (http://www.sonartrx.com/blog/)
The side scan sonar is a Humminbird 798ci.
PostPosted: Wed Feb 16, 2011 3:34 am
Added 2 more up in the original post...
Don't forget to use the slider to change the transparency of the sonar pic.
These ones are are nice and small and just contain areas of interest.
PostPosted: Fri Apr 15, 2011 10:59 pm
Added another side scan overlay. This time of Neutral Bay on Sydney Harbour. It shows the wharf area of the old HMAS Platypus naval base.
Direct link here-
http://www.pixel-landscapes.com/Sidescan/NeutralBayW/SonarTRX-R00018-20110416-012044/doc_web.kml
New page with all the links -
http://www.pixel-landscapes.com/Sidescan/Sidescan.htm
PostPosted: Sat Apr 23, 2011 2:05 pm
I have used several GPS devices and software to export KML files to Google Earth. This is the first time I have seen it used in conjunction with side scan sonar. Pretty cool application of the technology.
Users browsing this forum: zrkdjones and 2 guests
