It is currently Sun Jun 21, 2026 10:27 am
 Post subject: Trap line ?
PostPosted: Fri Mar 25, 2011 5:51 am
I am setting up my trapeze . what size and kind of braid line are you using hiking out? 3/16 - 5/16 Multiplait ?
Captn.
 Post subject: Re: Trap line ?
PostPosted: Fri Mar 25, 2011 6:45 am
Trap lines are actually wire. I have never seen rope used as a trap line on Hobie. There is a small amount of line used for the dogbone with a slide adjuster.
Howard
PostPosted: Fri Mar 25, 2011 10:31 am
I would try to find intrepid
Bodhisatfa
PostPosted: Sat Mar 26, 2011 7:50 am
Hey what is Up
PostPosted: Sat Mar 26, 2011 8:50 am
Yes the line on the dogbone , I have the trap wire and the bungee cord.
PostPosted: Sat Mar 26, 2011 10:29 am
This link should help, Captain - Click on the "line guide" hyperlink near the top of the page: http://www.hcana.hobieclass.com/default.asp?Page=3018&MenuID=Resources/10815/0/
PostPosted: Sun Mar 27, 2011 7:48 am
Intrepid line if you can find it.
Bodhisatfa
PostPosted: Sun Mar 27, 2011 9:13 am
The pre-stretched Dacron line that Hobie sells is really good and inexpensive. It fits the rope locks perfectly.
Sail Revolution
Join us on our new FB Page!
PostPosted: Sun Mar 27, 2011 1:33 pm
There's not that much load on the trap line, there should be no reason you coundn't use something other than the steel line.
